Thread: Tb6600?
I've still been searching around for drives and Im just sort of curious about the dm542t. Anyone know much about this drive? Is it worth it to invest a bit more money into this drive opposed to buying tb6600's? I know that contradicts a lot of my previous problem (cheapness) but it seems quite a bit more reliable and it's price isn't bad on Amazon.
Sent from my Nexus 4 using TapatalkLast edited by jtar40; 31-05-2018 at 09:37 PM.
31-05-2018 #2
The DM542T is an older Leadshine drive (IIRC it's the one that Leadshine essentially copied from Geckodrive), and is a good mid-budget drive. They'll certainly be a major improvement over TB6600 drives.
It's worth mention that I'm not sure how many sold are actually genuine Leadshine now, but even the copies are generally still reliable and good performance.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
01-06-2018 #3
Yes, it is MUCH better than the TB chip based drivers. I use a fake Leadshine, the DQ542MA, and been using those for over two years. They work nice, cool and quiet. Also my speed improved a lot after I started using those on the exact same CNC, only replaced the TB drivers with them. So, if you think those are a bit expensive you can always buy the cheaper DQ542MA, though the DM542T should be even better than that and I would not hesitate buying those today.
The Following User Says Thank You to A_Camera For This Useful Post:
TB6600 / HY-DIV268N-5A Problems, and possible solutions
By Doddy in forum Motor Drivers & ControllersReplies: 13Last Post: 23-01-2018, 10:24 PM -
TB6600 vs. CW5045
By eurikain in forum Motor Drivers & ControllersReplies: 0Last Post: 04-10-2015, 12:23 PM -
How hot do TB6600 drivers run normally ?
By KevinK in forum Motor Drivers & ControllersReplies: 4Last Post: 20-09-2015, 03:50 PM -
How to NOT destroy the tb6600 drives
By h500 in forum Stepper & Servo MotorsReplies: 0Last Post: 26-02-2015, 03:17 AM -
chinese TB6600 drivers
By jonnydeen in forum Motor Drivers & ControllersReplies: 6Last Post: 04-06-2013, 09:37 PM
