Good bit of background there, but you missed out a big detail - what sort of size machine are you looking at? And if it helps, my welded steel frame machine with a cutting area of something like 1500x750 cost around £3K to build.
Good luck - you've come to the right place, but be prepared for the flood of (sometimes conflicting!) opinions!
30-04-2018 #2
Thanks Neale
It is good to know that it is a feasible goal at least.
I have a (very rough and subject to change or advice) spec list of the following.
Y axis of 1000 to 1200mm
X axis of 600 to 750mm
Z of 200mm
Hiwin profiled linear rails on every axis
Ballscrews
Stepper motors (not sure best size 23/ 34 )
Proper spindle ie software controlled 2.2kw /3hp sort of size with decent sized collet for 12.7 mm router bits and end mills.
Limit/ homing switches.
Some kind of auto height sensor for when changing bits and setting up.
Very good dust extraction.
I think I might as well aim for something that will machine Aluminium even though it will be mostly for wood.I think woods like Macassar Ebony and Snakewood are nearly as hard as Aluminium anyway and sometimes i need to stabilise wood with epoxy too.
I would like accuracy and decent speed.
I am happy to buy parts direct from China (if supplier is reputable or recommended) as I am in no rush. Willing to adapt my size a bit if it is easier to use `standard` sized ballscrews etc rather than having them customised.
I am unsure if I should use a single central ballscrew for the Y or one each side.
I really have little clue about the electronics side of it regarding stepper drivers and the like but would like it to be able to run without being attached to the computer all the time if thats possible.
Very much open to suggestions regarding the electronics.
The machine must not be too enormous as I may need to move it, I am thinking a sort of `desktop` type with a Separate frame underneath maybe with wheels.
I have been thinking of using heavy duty alloy extrusion and plate as I have no welding skills but can probably manage to cut and shape alloy with some of the kit I have.
Thats all I have so far ?
Ollie
30-04-2018 #3
Hi Ollie,
Welcome, First good job on rejecting those that you did and you were spot on with your reasons.
Provided you have the skills and patience then it's possible to build quite a nice machine with the budget your thinking. However, it does take time and careful prep/design along with will-power not to rush out and buy stuff premature. From what I've seen so far with your research and decision making you seem to have the makings of successfull builder so with little help from us chosing the right components I'm sure you'll be fine provided your confident in your abilty's regards the actual building. Be honest with your self here because like most things which look easy there is more to it than appears.!
Good luck and don't be afraid to ask any questions you have, no matter how stupid they feel and DONT BUY ANYTHING WITHOUT ASKING or knowing it's 100% correct for your needs.
30-04-2018 #4
Thanks JAZZCNC, for the encouragement and words of warning.
I will ensure I don`t go on a spending spree without checking first.
My plan is to design the machine on Fusion 360 until it is going to definitely work as intended (this will take a while i think as I am new to the software). Once design has been finalised (and checked over on this forum) I will begin to gather parts and then get cracking on building it.
And now let the stupid questions begin.......
When beginning to draw up a design, is it better to find the sizes of linear rail and ballscrew that are readily available and size the frame to those existing components. Or just draw the machine out to the desired size and worry about those after?
Are Nema 23 steppers a good fit for a machine of this size, 1200mm maximum assuming a twin ballscrew design on the Y axis?
Is there a best practice order of design? Z axis first, gantry (X) first or any other methodology?
Enough questions for now I think.
Ollie
01-05-2018 #5
Which would you like to do? I started my machine around 3 years ago, and at that time I was nervous about ordering from China. I designed my router to the size I wanted, worked out rail/ballscrew dimensions, found a uk supplier who sold standard sizes, and redesigned to use the next off-the-shelf size up. Hiwin rails cut easily with an angle grinder but ballscrews need fiddly end machining which is beyond most people at home. These days, I would probably spec exactly what I wanted and order from someone like BST Automation in China.
Nema 23, 3Nm or (better) 4Nm, would be fine for X and Y for this size machine. Important parameter is motor inductance, so check back before buying! But at least you have a frame size for planning purposes.
01-05-2018 #6
Design the machine you want then have the components made to size. It's highly likely because of budget you'll buy Rails and ballscrews from China and they will machine ballscrews to your spec. Same with rails, they'll cut to your exact size or like Neale says just buy little longer than needed and cut your self.
The important part is choosing the correct diameter and pitch to suit your machine. Depending on length you'll also take into consideration end bearing type but don't worry about that yet your still some way off worrying about those things.
Yes perfectly fine but need to look closely at the spec because not all steppers are equal and come in various flavors ie: 4 wire 8wire.
Like Neale indicated the inductance rating is important but this rating changes depending how the phases are wired so you'll need to understand this to get full picture. Without getting too technical I'll explain quickly the differences and why one type/setup suits Router better.
The phases of Steppers can be wired in 3 ways depending on how many wires motor come with. These are Bi-polar series, Bi-polar parallel, Uni-polar. With Modern drives only the first two of those are used so won't explain Uni-polar.
Series Wired motors generaly provide high torque but require high voltage to achive high RPM. This is because the inductance is much higher.
Think of inductance like pushing car with sticky brakes and the people pushing being the voltage. The more sticky the brakes the more people needed to push car the same speed.
So lower the inductance the less voltage will be required to achive same speed as high inductance motor, or put another way, with same voltage the motor will spin faster if inductance lower.
So series wired motor are generaly best used for machines like Mills or Lathes which don't require high feed rates(rpm) but do require more torque due to heavy design.
Also because series wired motor uses roughly half the current of Parallel wired motor smaller lower cost drives can be used.
Parallel wired motors are pretty much the opposite. The inductance is half that of series wired so require less folks to push, down side being when going uphill those folks will need to be stronger. In real terms what this means is that double the current will be required when wired parallel.
In performance terms what this allows is that higher RPM can be achieved and they hold the torque further up the RPM range, down side being there is less torque at lower RPM.
Now this is where it gets little confusing to people because motors come in 4 wire and 8 wire(often called Hybrid).
4 wire motors are fixed by the manufacturer and can be wound either series or parallel, often they are series wound.
8 wire motors can be wired in either way by joining wires in certain order. (they can also be wired Uni-polar)
So cutting to the chase for Router builder your better using 8 wire motor with low inductance when wired Bi-polar parallel. This setup when combined with correct voltage(65-70Vdc) gives best performance.
Like any good structure it all starts with solid foundations. Design from the bottom up and each will form the other.Last edited by JAZZCNC; 01-05-2018 at 07:32 PM.
02-05-2018 #7
In terms of the machine design process it is fairly iterative and you need to go around the loop many times as every choice has a knock on effect that ripples through the design.
Assuming you are building a fairly standard machine with moving gantry and raised X axis then I'd suggest you draw the spindle with your favourite tool in the collet and place the tip about 150mm above the top of the bed plane.
Draw the Z axis plate that holds the spindle and make it say 300-350 mm tall by 150 wide. The bottom of the plate should not be lower than the main spindle body. Add the Z rails to the back of this plate making them at least 300 mm long and ideally matching the height of the Z plate.
Add the lower carriages to the Z rail placing them no lower than the main body of the spindle. In the CAD program slide the Z axis (spindle, Z plate and Z rail) down until the tool hits the bed plane. The lower carraiges should remain in place.
Add the upper Z carraiges near the top of the rail, leaving 10mm or so if you want a bit spare to face the bed.
Draw the Y axis plate which hold the Z carraiges on the front side. On the rear of this plate add the Y carraiges making sure they do not clash with the Z carraiges and that it can be assembled!
The Y rails can then be drawn to fit the Y carraiges and the gantry drawn.
Add horizontal plates on the ends of the gantry and fit the X carraiges to the underside. This dictates the X rails position.
Draw the frames to hold the X rails and then add vertical supports under these frame sides to connect down to the bed frame.
Add the steppers, ballscrews, ballnuts, and ballscrew mounts and the fun starts. Things get tweaked and moved to get it to work. I would say this bit takes the most time so hang in there.
Finally plenty of advice on hand on this forum to guide you. Best of luck!
02-05-2018 #8
Thanks for the great responses to my questions.
I was thinking of starting with the Z or the spindle as you suggest routercnc. I can see what you mean about everything affecting everything else which was partly where my difficulty starting.
This gives me a good start.
Great tip about setting the height from the bed to the tool straight away.
I will remember Jazzcnc`s comment about starting with the strong base too....
Do you do suggest sort of rough drawing on fusion (or whatever software ) first just using plain rectangles etc, to get the shape and then do a proper one with the profiles of the extrusion and the carriages etc, or just go straight in with the full detail.
I have been attempting to gather dxf files of aluminium extrusions and the Hiwin stuff. does anyone have a source to a library of this sort of thing.
Ollie
can someone please help with hole dimensions
By reefy86 in forum SolidworksReplies: 38Last Post: 20-02-2016, 12:44 PM -
Hole Radius
By benkat in forum Machine DiscussionReplies: 0Last Post: 03-03-2014, 05:29 PM -
SBR16UU Centre hole.
By cambesol in forum Rails, Guideways & BearingsReplies: 3Last Post: 25-11-2013, 05:39 PM -
HELP! Problem drilling 2.39 dia hole in Ali casting
By woolley2002 in forum Machine DiscussionReplies: 4Last Post: 04-09-2013, 09:06 AM -
6mm shaft to 6.35mm hole?
By JuKu in forum Metalwork DiscussionReplies: 3Last Post: 15-12-2012, 02:29 PM
