Thread: making very fine slots...
Good try John, but the slots have to be a controlled length, not right to the edge.
09-09-2009 #2
Oops missed that bit.
What about doing this on a 54mm disk and pressing a 3mm ring on afterwards ?John S -
09-09-2009 #3
laser - I doubt they will cut copper alloys
edm - yes but at a cost
0.2mm milling cutter in a top-notch cnc - no problem
0.2mm milling cutter in a converted drill/mill 1 or two notches then snap...
How about photo-etching?Last edited by BillTodd; 09-09-2009 at 11:43 AM. Reason: typo foxed
09-09-2009 #4
Laser will cut brass but the edge finish is $hit and at 0.23mm wide probably impossible.
Spark eroder will do this no problem but you need a graphite or copper master and cutting this gives the same problems as cutting the slots.
What is it for ? can the design be altered to suit a better method?John S -
cutting a fine line
By cubikoman in forum Tool & Tooling TechnologyReplies: 6Last Post: 19-02-2017, 10:04 AM -
Any tips for deep slots/profiling in aluminium?
By m_c in forum Metalwork DiscussionReplies: 9Last Post: 18-04-2014, 12:00 AM -
Taunton's Fine Wood Working
By Lee Roberts in forum Wood Finishing Tips & TricksReplies: 3Last Post: 06-04-2012, 11:49 PM -
Fine pitch Bolts
By Normsthename in forum General DiscussionReplies: 1Last Post: 13-08-2010, 11:13 PM -
Making a Jig
By Wobblybootie in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-06-2010, 11:17 AM
