Thread: Shallow channel/Contour
07-05-2018 #1
07-05-2018 #2
Could it be that the tool is the same diameter as the pocket is wide..? - Try telling F360 that the end-mill is ⌀1.999mm*
*It's what I have to do in Vectric's software...
Wal.
08-05-2018 #3
You could use a ramped profile cut based on one edge of the pocket (slot?)
To work optimally a lot of CAM users utilise extracted and/or constructed geometry to generate the paths they need rather than purely relying on the solid model,
08-05-2018 #4
I had this problem with a scratchplate for an Ibanez guitar this weekend - the way I got it to work was to get rid of (untick) the Lead In and Lead Out options in the last tab on the toolpath dialogue.
Hope that helps.
Edit: Nearly forgot - set the Ramp option if you haven't already.Last edited by Washout; 08-05-2018 at 11:44 AM.
My CNC Projects: https://www.youtube.com/imadethisoncnc
08-05-2018 #5
08-05-2018 #6
08-05-2018 #7
No worries and glad it worked.
I think this "feature" was introduced in the last update or so, as I think it used to drop the lead in/out if there wasn't room for it.My CNC Projects: https://www.youtube.com/imadethisoncnc
Thread milling shallow bind hole
By suesi34e in forum Metalwork DiscussionReplies: 28Last Post: 15-12-2015, 01:03 PM -
Tips and tricks for shallow milling/ engraving ?
By Gasgasbones in forum General DiscussionReplies: 17Last Post: 11-01-2015, 09:39 PM -
Youtube/Video Channel Thread?
By Washout in forum General DiscussionReplies: 2Last Post: 29-05-2014, 02:24 PM -
where do you get the v groove channel extrusions from
By nobby in forum Marketplace DiscussionReplies: 1Last Post: 29-04-2014, 04:19 PM -
What's the diffrence in the 5V 4-Channel Relay vs a ZP-4WAY-RB
By boldford in forum General ElectronicsReplies: 1Last Post: 05-09-2012, 05:25 PM
