Thread: CNC Router Aluminium surfacing
Do you want flatness or finish ? to put a surface pattern I use a dremel wire brush, the lowest spindle speed and WD40 (otherwise it drags the ali and messes the finish). I use a pocketing cut at a fairly high feed rate and 0.2mm DOC. The dremel brush must be the genuine one like these DREMEL Multipack Accessories 443 3 x 3.2mm Carbon Steel Polishing Brush Pack 3. If you spin it too fast it splays out and is useless from then on.
For a flat surface - yes the 6 or 8mm HSS uncoated cutter from ArcEuro, when they have them.
09-05-2018 #2
Hi
Its flatness I need. I'm going to run some tests this evening. Bare in mind my machine is a china cnc 3040 so not the greatest thing. I've got a quite a few endmills I'll upload some images so you can see.
I'm only a hobbiest and still working on feeds speeds and general use of the machine. My time is very limited these days but I'm doing things in small drabs.
Sent from my SM-N910F using Tapatalk
09-05-2018 #3
09-05-2018 #4
BUILD LOG: Not the avarage aluminium router
By Sven in forum DIY Router Build LogsReplies: 8Last Post: 25-01-2017, 02:42 PM -
BUILD LOG: Aluminium FEA optimalized CNC router
By PotatoMill in forum DIY Router Build LogsReplies: 65Last Post: 28-07-2016, 08:25 AM -
Surfacing bit and t-slot bit
By eurikain in forum Workshop & EquipmentReplies: 11Last Post: 25-04-2016, 01:58 PM -
Surfacing Spoiler board
By CommanderKenyon in forum Machine DiscussionReplies: 7Last Post: 08-10-2015, 01:47 PM -
Spoilboard Surfacing - What tool(s) do you use?
By Mad Professor in forum Tool & Tooling TechnologyReplies: 6Last Post: 12-01-2013, 11:55 AM
