    Yes tool needs to be @ centre height,would still use HSS tool.I tend to run a fairly slow speed to prevent vibration in the boring bar,when you get to the bottom of your bore reverse the feed and you will find it will probably take a fine cut on it's way out. some sort of cutting oil will help.
    Thank you ill give that a go later. I am running my lathe @ 2000 rpm. I have either 250, 500, 1000, or 2000 rpm options.
    Try 250 see how it goes, it's a bit of trial and error depending on material/machine stiffness ect. just have a play
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    By the sounds of it, you want a less springy boring bar.
    Use as large a boring bar as possible, and if you really do have to use a relatively long overhang from the tool post, a carbide bar will help as it's not as springy.
    As mekanik says, HSS should help, as it's a sharper edge, and not relying on a blunt edge with brute force to cut the metal. Although one thing you could try if you have an insert bar, is use an aluminium insert, as they typically have sharper edges than inserts for steel. You won't be able to take as big a cut, and the insert won't be as durable, but should produce a smoother finish.
    And a key thing with inserts, is keep them cutting. Don't let them rub.
    thank you for responding.
    Still struggling with it not sure if i reach the limitation of my lathe if its my tools. Ill see if i can find some more time to have another go.
    Have you got a fixed steady to support the end of the tube ?
    i havent no. i could look at making one if that is what i need
  1. Adjustable Boring Bar
    By jamesgates1000 in forum Tool & Tooling Technology
    Last Post: 18-05-2016, 07:57 PM
  2. help needed boring 8mm holes 20mm depth in Alu
    By Noplace in forum Metalwork Discussion
    Last Post: 24-04-2016, 01:27 PM
  3. Kaiser Adjustable Precision Boring Head + Tool Holder
    By Jim Jordan in forum Classified Ads, Buy, Sell & Swap
    Last Post: 30-09-2015, 10:01 AM
  4. Boring Bar Suggestions?
    By Washout in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 21-06-2014, 08:59 AM
  5. Recommendations for low cost MT3 boring head...
    By irving2008 in forum Tool & Tooling Technology
    Last Post: 19-08-2009, 10:15 AM
