    Hi all does anyone have the above for sale or know where I can get mine repaired,
    many thanks
    Ade
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 4 Days Ago Has a total post count of 1,654. Received thanks 115 times, giving thanks to others 71 times.
    Ade,
    You might find that repairing it is cost prohibitive. If I was in your shoes, I'd consider getting a replacement Servo Drive / Motor (400 W) from a range of different suppliers and changing out the Z axis.
    The Y Axis motor is difficult to work with (space). The X is fairly easy but if it was me, Id want to keep X and Y the same motors. The Z axis is obviously very different and the motor bracket is fairly easy to modify. You can easily take a plate and modify and then once your machine runs, mill a new one or give me a drawing and I can do one for you.
    Charl
    Hi Charl
    Good to hear from you, yes your correct I have swapped the Y with the Z to give me identical drives on X and Y it also makes the panel look good. Do you know of a suitable package to replace with.
    Ade
    Chaz's Avatar
    Ill post some links later tonight when I get home. A quick search for 'servo drives / motors' on this forum will also yield some results. Choice then to either buy locally or abroad, pending cost / time / support requirement.
    Chaz's Avatar
    So, some options are:-
    Zapp - Drive - https://www.zappautomation.co.uk/ele...range-344.html
    Zapp - Motor - https://www.zappautomation.co.uk/ele...ors/smh60.html
    and of course you need some cables too.
    http://www.dmm-tech.com/ http://www.dmm-tech.com/Dyn2_v2.html and matching motor, will also need cables.
    http://www.jmc-motion.com/ - have emailed you some further info there.
    Loads of other options if you look around.
    Chaz's Avatar
    And, sorted?
  1. Which metal would flex more?
    By PaisleyPCdoctor in forum Milling Machines, Builds & Conversions
    Last Post: 25-02-2018, 04:29 PM
  2. Need to get a Baldor F391 board scematic diagram.
    By mike dempsey in forum General Discussion
    Last Post: 12-01-2018, 06:30 PM
  3. CSMIO/IP-M with baldor smartstep/3
    By Benja in forum Denford Mills
    Last Post: 03-07-2017, 12:44 PM
  4. RFQ: laser cut - very simple rectangular parts, PTFE and other flex plastics
    By dsc in forum Projects, Jobs & Requests
    Last Post: 19-06-2015, 12:59 AM
  5. chain drive
    By jonm in forum Linear & Rotary Motion
    Last Post: 07-03-2010, 02:36 PM
