  1. #13
    looking at your photo of the terminals
    this is how I would connect to the VFD
    with the forward on/off control being BOB's the relay controlled by pin 17
Name:	nowforever vfd terminals.jpg
    yes
    the relay switches the VFD on in the forward direction
    and is the simplest control with one switch
    depending on the parameters set for input X1
    you could have 3 switches
    one for on / off
    a second for forward that works in conjunction with the on /off switch
    the 3rd being reverse that works in conjunction with the on /off switch
    John
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Centec 2A rebuild
    By Web Goblin in forum Gantry/Router Machines & Building
    Last Post: 02-04-2013, 08:41 PM
  3. REBUILD: Blomqvist lathe rebuild
    By Web Goblin in forum Lathe Rebuild Logs
    Last Post: 21-09-2012, 06:52 PM
  4. Stepper Driver Rebuild
    By fidia in forum Motor Drivers & Controllers
    Last Post: 25-05-2011, 02:44 PM
  5. NEW MEMBER: New member wants to rebuild.
    By black5f in forum New Member Introductions
    Last Post: 21-06-2010, 11:38 PM
