  1. #8
    assuming you are using mach 3
    I expect in ports and pins you have
    X axis step = pin 2 , direction= pin 3
    Y axis step = pin 4, direction = pin 5
    Z axis step= pin 6 , direction= pin 7
    if that is correct
    change the Y axis to
    Y axis step= pin 8 , direction = pin 9
    then connect the " A axis " output terminals 8 & 9 to the Y axis stepper driver
    John
  2. The Following User Says Thank You to john swift For This Useful Post:
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Centec 2A rebuild
    By Web Goblin in forum Gantry/Router Machines & Building
    Last Post: 02-04-2013, 08:41 PM
  3. REBUILD: Blomqvist lathe rebuild
    By Web Goblin in forum Lathe Rebuild Logs
    Last Post: 21-09-2012, 06:52 PM
  4. Stepper Driver Rebuild
    By fidia in forum Motor Drivers & Controllers
    Last Post: 25-05-2011, 02:44 PM
  5. NEW MEMBER: New member wants to rebuild.
    By black5f in forum New Member Introductions
    Last Post: 21-06-2010, 11:38 PM
