  1. #27
    Hi There,
    Nice looking box and work - Some ideas
    1.) Fans - Try not have the fans on the same surface as the air will just go in and out across that surface you would want the air to go across the box as much as possible so maybe one on the bottom front into the box and one on top of the box - sort of how they do it on PC cases. you can always get a multi meter with a heat sensor to check your internal temps of the components
    2.) EMI and Ground Loop - it's always difficult to know if putting so many switch mode power supplies close together will cause EMI issues. when you connect your table make sure you don't create ground loops. my machine is all aluminum and I was happily making ground loops all over my table.
    Quote Originally Posted by Palletlad View Post
    Hi all, I'm having another go at the control box to get rid of the gremlins.
    My first attempt failed ended up killing my drivers and breakout board with a static discharge (so I've been told) so have brought a new container with a metal backing and have started from scratch a new design.
    I have made a video in order for you to review and see with your experienced eyes anything that stands out as good/bad, criticism is all welcome.
    https://www.youtube.com/watch?v=FL1fY_2_VPo
  2. The Following User Says Thank You to erasma For This Useful Post:
  1. REBUILD: Hardinge HC rebuild
    By northumbrian in forum Lathe Rebuild Logs
    Last Post: 21-02-2017, 12:07 PM
  2. Centec 2A rebuild
    By Web Goblin in forum Gantry/Router Machines & Building
    Last Post: 02-04-2013, 08:41 PM
  3. REBUILD: Blomqvist lathe rebuild
    By Web Goblin in forum Lathe Rebuild Logs
    Last Post: 21-09-2012, 06:52 PM
  4. Stepper Driver Rebuild
    By fidia in forum Motor Drivers & Controllers
    Last Post: 25-05-2011, 02:44 PM
  5. NEW MEMBER: New member wants to rebuild.
    By black5f in forum New Member Introductions
    Last Post: 21-06-2010, 11:38 PM
