    I bought a piece of silver steel from J D Multi Metals in Sheffield via Ebay. 333mm x 3mm dia. It took 6 days over the projected delivery time to arrive and when I got it, it was bent, having been taped to a piece of card as the only protection.
    I took most of the obvious kink out with my thumbs, but my question is - should I have been able to? I thought silver steel was supposed to be a lot stiffer than mild steel.
    Could it just be a poor grade of silver steel ?
    Anyway, I shan't be buying from that firm again !
    Cheers,
    Rob
    Hi Rob
    @ 3mm Diameter you would be able to bend it, after it's been hardened it would break.Has it got a ground finish ?
    regards
    Mike
    Lives in East Lothian, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 375 times, giving thanks to others 9 times.
    Silver steel can be bent. It's just a carbon steel supplied in an annealed state, although it should be a bit tougher to bend.
    I'm sure a google for yield strength will turn up some figures.
    Thanks chaps ! My points were, It seems to be as soft as mild steel and was posted just taped to a piece of cardboard. Royal Mail must have given it more than a casual 'chuck it in a sack'.
    Anyway, I can't use it as I can't get it straight enough. I will buy a shorter length of tool steel or stainless.
    Yes Mike, it is ground.
    Cheers,
    Rob
    Wal's Avatar
    I take it that the cardboard survived the journey..? :)
    Wal.
    Wal.
    No, it wasn't engineering grade cardboard (like Medite)
    Rob
    Wal's Avatar
    Shysters..!
    Wal.
  1. Advice needed on everything
    By chrisjames in forum General Discussion
    Last Post: 11-11-2015, 11:40 PM
  2. Steel Frame 8' x 5' CNC - Advice Sought
    By BrentonSpear in forum Gantry/Router Machines & Building
    Last Post: 01-06-2015, 11:12 AM
  3. First steps, advice needed
    By Wobblycogs in forum Gantry/Router Machines & Building
    Last Post: 02-11-2012, 02:30 PM
