    Hi all
    hope you are all well
    simple sanity question, in mach3.. under MDI
    I type G0 Y10
    AND THE Y AXIS MOVES TO POSITION 10, 10MM (MACHINE MOVES CORRECTLY AND MACH DRO READS 10)
    I TYPE G0 Y0
    AND Y MOVES BACK TO POSITION 0 SAME AS ABOVE APPLIES
    I DO THE SAME WITH Z (STARTING FROM 0 DRO ALSO 0)
    G0 Z10 - AND Z MOVES TO 22.92 AND THE DRO REFLECTS THAT
    THEN G0 Z0 AND IT MOVES TO 12.92
    I HAVE MACH3 UNITS PROFILE SET TO MM
    IF IT MAKES ANY DIFFERENCE I AM IN THE PLASMA PROFILE
    ANY HELP GRATELY APPRECIATED
    (IF I JOG THE Z (OBVIOUSLY NOT VERY ACCURATELY) BUT 1.0MM ON DRO IS 1MM PHYSICAL ON Z
    Did you home the axis first? Is Z0 at the top? If so all moves need to be negative so G0 Z-10 should move 10mm down.
    Have you checked that you don't have a scaling factor set on the rogue axis?
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Looks like there's some kind of offset being applied to the Z axis.
    Just a little possibility to throw into the soup - I once was trying to calibrate/tune the axis and got asymmetrical offsets positive and negative - took me a while to realise the column was at the limits of its travel (I only have home switches at the top of the column)
  1. Mach3 - weird coodinate shift with inch/mm gcode change
    By Neale in forum Artsoft Mach (3 & 4)
    Last Post: 17-02-2019, 12:06 AM
  2. The best CAD/CAM suggestion, Gcode and Mach3
    By petes in forum CAD & CAM Software
    Last Post: 29-01-2015, 11:06 AM
  3. Help needed for a 3d part gcode for mach3
    By Rebekah_harper in forum Computer Software
    Last Post: 04-11-2013, 01:55 AM
  4. Replies: 1
    Last Post: 20-10-2012, 02:50 PM
  5. Mach3 Using a physical button to repeat current gcode
    By RLKS Rob in forum Artsoft Mach (3 & 4)
    Last Post: 12-08-2012, 01:30 PM
