Page 1 of 3 123 LastLast
    Wal's Avatar
    Hi all,
    Just wondering if anyone has any experience with building an etch press - something along the lines of this:
    I've started to design one and have begun collecting odds and sods that I'll be using along the way (take-up bearings, flange bearings etc.)
    One thing that's got me a bit stumped, though, is how to get my hands on a pair of live shaft stainless rollers. I'm attaching a .pdf of what it is I'm after. Dimensions are approximate at the moment, but won't be far off that. The long 60mm shaft will need a flat on it for the hand-wheel grub-screw to bite on.
    Ok, there's the obvious way, pay someone to turn 'em - I imagine this will be pretty pricey, given the chunkiness of what I'm after, but if you know any different then let me know..!
    Or I could fabricate 'em from a steel pipe with a steel shaft passing through it held central by a couple of alu caps made on the mini-mill. (All probably glued up with the strongest epoxy I can find...)
    Any other ideas..?
    Wal.
    Even with a lathe I'd be temped to centre drill stock 50mm stainless bar pre-cut to length, bore out (or drill) then ream to 15mm dia and maybe 40mm depth, then tap some 15mm dowel into the reamed holes with some loctite.
    I wouldn't bother trying to turn down the 50mm bar. At least with my ML7 (small spindle bore) I'd have to turn between centres.
    I guess there's a reason it has to be stainless?
    Wal's Avatar
    Having just read a bit more on the topic, the drive roller would be fine in 7075T6 with the idler in mild steel - had stainless in mind as it's what (little) I remember from the college art room... The crucial bit is that the rollers run absolutely parallel to each other (this can be tweaked via the take-up bearings) and that the running gear can withstand high pressures.
    I may well have to consider increasing the shaft diameter to a more substantial 20mm and have a closer look at using self-aligning bearings to accommodate said tweakage... This could get a bit pricey...
    Wal.
    Hi Wal,
    This build uses tube for the rollers
    https://www.youtube.com/watch?v=UhlSZU63S7g
    and these for the pressure adjustment
    http://www.arceurotrade.co.uk/Catalo.../Take-up-Units
    Interesting project, but not for me (too many projects stalled on the bench )
    Cheers, Rob
    Wal's Avatar
    Cheers Rob - that clip makes it look too easy..!
    Wal.
    Wal.
    If you made a cock-up, would you edit it out of the video - Just asking
    If you could find an old number plate machine you'd have no work to do, they're effectively a heavy duty mangle with geared steel rollers.
    Hi all,
    Any other ideas..?
    Wal.
    Hi Wal,
    Don't know if this could be what you need but I have a 610mm x 50mm dia with a 30mm bore through it Stainless steel rod, I also have a piece of 465mm x 32mm dia solid stainless bar which would turn down for the ends.
    All you would need then is someone with a large enough lathe to turn down the ends to fit into the tube then skim off true the tube and away you go, easy!
    Phill
    Wal's Avatar
    Hiya Phil,
    Thanks very much for the heads-up on those materials.
    I think I'm leaning more towards the 'one-piece' solution as it'll probably end up easier communicating what it is I need doing to a shop (and will result in fewer steps for them to take to get it made). From a strength point of view: these rollers need to take around 40Kpsi - I'm guessing that by sliding the shaft through the middle like that you'd be talking about a fairly substantial non-slip interference fit along the length of the roller - not sure what kind of stresses that would introduce and how they'd interact with additional stresses that the printing process will put 'em through...
    Wal.
    Wal's Avatar
    Still doing my research on this (materials, why some have a spring under the take up bearing etc.) but this is how the design is shaping up so far...
    Wal.
  1. New drill press. Which???
    By Snapper in forum Metalwork Discussion
    Last Post: 21-01-2017, 10:53 AM
  2. VFD for drill press
    By Noplace in forum Motor Drivers & Controllers
    Last Post: 31-03-2016, 12:09 PM
  3. WANTED: Drill press
    By D-man in forum Items Wanted
    Last Post: 30-08-2013, 07:45 AM
  4. RFQ: Press cost question ?
    By Fivetide in forum Projects, Jobs & Requests
    Last Post: 01-12-2012, 08:26 AM
  5. Bearing interference fit / press fit
    By Mad Professor in forum General Discussion
