Thread: spindle not firing up
Threaded View
18-05-2018 #1
my 6040 has been gathering dust a while as i had no pc with a parelell port. Eventually i got one of those unc300eth gizmos which was easy enouth to hook in. i reconfigured mach3 to talk to it but for some reason i can not get the spindle to fire up unless i do a major config changes then it fires up until i hot the reset button. the pin goes high when i press the spindle button. I hear a relay clicking and the rpm on the software spins up only to spin back down again. the spindle never moves, unlessi do a major config change. plug it from port 2 to three etc
not sure what's going on. all the steppers work fine.
Wny ideas please?
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
