    Chaz's Avatar
    As per the title, Id like to build up some stock of various size shim stock. The stuff I am finding is very expensive.
    Why / when do you use steel vs copper?
    Any suggestions welcome.
    What do you call very expensive?
    I've used "Shim in a Tin" from my local bearing and seal suppliers in the past at around £12 per tin, and cheap feeler gauge sets when I needed a wide range of shim thicknesses, intended application might help folks suggest viable options based on size and availability,
    - Nick
    Chaz's Avatar
    Thanks. I looked and found rolls for > £100, cant find it now. This gives me options at least, thanks.
  1. Stock on facing
    By dfox1787 in forum Fusion 360
    Last Post: 22-01-2018, 01:44 PM
  2. roundbar stock
    By dfox1787 in forum Vectric
    Last Post: 10-01-2018, 02:51 PM
  3. where to buy stock aluminium
    By dfox1787 in forum Marketplace Discussion
    Last Post: 27-12-2017, 11:27 PM
  4. Metal Stock Purchasing UK
    By paul_m in forum Metalwork Discussion
    Last Post: 25-05-2015, 04:42 PM
  5. Method for holding Stock
    By Chaz in forum Machine Discussion
    Last Post: 24-06-2013, 11:41 AM
