    What do your Offset Setting Scripts do for you and could you do the same in a usable fashion from CAM?
    If you can offload your variability to CAM go for a stand alone controller, it seems daft to spend a few hundred pounds and still be dependent on a PC.
    YMMV
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Is this for a lathe?
    (I'm going by the fact you mention turning offsets...)
    If it is, then you have to be aware not everything supports turn, and even those that do, may require some changes (I.e. not all support single slot indexing for threading).
    Regardless of the option taken, there is going to be some amount of pain. Keeping an old 32pit PC may be the path of least effort.
  1. Mach 3 Help
    By RichardR in forum Artsoft Mach (3 & 4)
    Last Post: 04-08-2016, 12:21 PM
  2. RFQ: Triac / Mach 3 help
    By suesi34e in forum Projects, Jobs & Requests
    Last Post: 10-08-2013, 01:59 PM
  3. NCStudio or Mach 3 or something else?
    By Fivetide in forum Machine Control Software
    Last Post: 01-09-2012, 05:41 PM
  4. mach 3 help
    By 1albobs in forum Artsoft Mach (3 & 4)
    Last Post: 27-02-2012, 03:34 PM
  5. MACH 2008
    By Lee Roberts in forum General Discussion
    Last Post: 05-10-2007, 09:48 AM
