Thread: Verification please
Hi
Finally took the courage and started to cut some wood this evening after so much checking and double checking of a new replacment build.
Using a CRP2448 with the 2.2kw spindle i did the model in Fusion then output to Mach3.
I want to cut 'sapele' and i have set a 10mm Bull Nose cutter in an adaptive cut at 8000rpm and 3800mm/min. This seems to be what i keep coming too with various checks.
So i start the climb cut and it goes down to 10mm doc and as far as i can see 2mm width (although in fusion it says opt load 4mm), it runs sweet along the grain but when it went across it chattered like hell and i had to stop it.
It may be that i have not secured it absolutely rock solid and its that, but tbh i had got it much more secure than any i have done before due to the nature of the beast i am now using (used a High-z 720 before.)
Can anyone who may have cut this type of wood before offer any advise please
thank you malcLast edited by BernieNUFC; 21-05-2018 at 08:56 PM. Reason: 'climb' added
21-05-2018 #2
Sapele is quite hard. 10mm doc is probably way too much for an aluminium framed machine. Might work if your bit is razor sharp
The Following User Says Thank You to battwell For This Useful Post:
22-05-2018 #3
The cutter is brand new, i would not normally cut to this DOC but the rave is that adaptive is able to do just that so hence why i tried it out :-)
cheers for reply
22-05-2018 #4
Machine rigidity is key to cutting capability.
The Following User Says Thank You to magicniner For This Useful Post:
22-05-2018 #5
22-05-2018 #6
Ball Nose Cutters all suffer from zero cutting speed at the very tip, have you considered roughing with a straight cutter and finishing with with the Ball Nosed cutter?
Limit switches PCB schematic verification.
By cncnoob in forum General ElectronicsReplies: 18Last Post: 25-02-2013, 09:28 PM
