Thread: Drilling holes on cnc
25-05-2018 #20
Crikey, you must have issues with your CAM or machine!
I've never broken a milling cutter when using a helical path to cut a hole slightly larger than the cutter up to 5 diameters deep. Provided you use air nozzles to clear chips it's a very low stress job for the cutter, climb milling with a very small step over and DOC, it's a quick process too and ideal if your spindle only does high speed.
This strategy also works well for jobs where it's faster to machine an appropriate starter or guide hole then finish on a manual drill press.You think that's too expensive? You're not a Model Engineer are you? :D
Drilling Ø0.2mm holes on aluminium
By hoezap in forum Metalwork DiscussionReplies: 5Last Post: 09-04-2016, 06:28 PM -
RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
By alixus in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-05-2015, 02:39 PM -
RFQ: West London, Park Royal, Acton Area. 4 holes CNC drilling in my new Spindle mount & Z
By stuboy in forum Projects, Jobs & RequestsReplies: 2Last Post: 16-08-2013, 06:40 PM -
RFQ: 5 Axis Hole Drilling in Plywood - 1260 holes in 64 boards - help very much needed!
By pjm699 in forum Projects, Jobs & RequestsReplies: 3Last Post: 16-08-2012, 08:50 AM -
Drilling force monitering/chipped drill detection/1000's of holes in SS
By PatK in forum Tool & Tooling TechnologyReplies: 3Last Post: 27-09-2011, 11:57 PM
