    Are there special drill bits needed for a cnc?
    I know my spindle has certain collet sizes so standard bits are unlikely to fit.
    Chaz's Avatar
    Get good quality bits and get your speeds / feeds right.
    If you have the typical 24K RPM low torque spindle, its more difficult. Small holes are OK, large ones you will struggle.
    how about fitting them in the colet? Are you talking about bog standard drill bits or do they have special bits for cncs?
    Quote Originally Posted by dfox1787 View Post
    You could throw us a bone and tell us so we don't have to guess or assume?
    lol ok max collet size 12mm. Im only asking if there a special drill bits for cnc
    Lives in East Lothian, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Drill bits are not specific to CNC, however you do get lots of options which may suit a particular application far better.
    Have a browse of the Phantom Drills website, and try finding a copy of their catalogue if you want to see just how many options are available.
    Wal's Avatar
    Why not - you're using an ER system, aren't you?
    Anyway, as m_c said, there are plenty of options out there - a cursory search brought this up:
    https://www.cadem.com/single-post/cn...l-helix-angles
    Not a bad place to start. As per Chaz's advice - yep, it can be a bit hit and miss with the 2.2kw Chinese spindles - you don't want to go too fast and burn up the drill, but you really don't want to drop much lower than 9krpm as you risk stalling the spindle...
    One thing I would say: make sure you spot drill first..! If you're using standard drill lengths then you can expect a bit of a squeal on the first peck, but that should disappear once the drill gets a bit deeper... Here's a vid of my machine drilling out a section so that I wouldn't have to deep slot (fast forward to about a minute in). I'm sure I could've gone a bit quicker, but you know - when you find something that works you tend to keep it that way..!
    Good luck.
    Wal.
    For general purpose drilling, I'll normally get Cobalt drills. More durable than pure HSS, but typically slightly more brittle (not as brittle as pure carbide though!), and can handle higher speeds than pure HSS (but no where near as high as pure carbide).
    Polished ones for aluminium, and suitably coated ones for steel.
    Key thing is to ensure you are within the speeds/feeds specs for the drill, and as Chaz/Wal say, with Chinese spindles that can be a problem. You'll likely get better results on larger holes by either pre-drilling then milling to size, or just helix milling.
    Spot drilling depends on what you're doing. I generally only use stub drills with split point (or whatever the manufacturer wants to call their self-centring drills), which I'll never spot drill first. However anything I need to use any longer a drill on, I'll generally spot first.
    https://www.youtube.com/edit?o=U&video_id=uwDesJPd6a0
    Good luck.
    Wal.
    Hi Thank you for this.
    Ill take a look into those bits. My spindle is the ER system. The min rpm i can get is 10000.
    The link you sent me takes me to the video edit part on my youtube. Id love to see the video though
    Wal's Avatar
    Oh - and coolant wise: WD40
    I do my best to avoid it like the plague nowadays. Useful, but once it atomises and hangs in the air it's nasty stuff. Instead I try to plan better, use decent materials that cut well and as much air as I can get on the part...
    Wal.
    Sent from my HTC One M9 using Tapatalk
  1. Drilling Ø0.2mm holes on aluminium
    By hoezap in forum Metalwork Discussion
    Last Post: 09-04-2016, 06:28 PM
  2. RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
    By alixus in forum Projects, Jobs & Requests
    Last Post: 06-05-2015, 02:39 PM
  3. Replies: 2
    Last Post: 16-08-2013, 06:40 PM
  4. Replies: 3
    Last Post: 16-08-2012, 08:50 AM
  5. Replies: 3
    Last Post: 27-09-2011, 11:57 PM
