    You could throw us a bone and tell us so we don't have to guess or assume?
    lol ok max collet size 12mm. Im only asking if there a special drill bits for cnc
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Drill bits are not specific to CNC, however you do get lots of options which may suit a particular application far better.
    Have a browse of the Phantom Drills website, and try finding a copy of their catalogue if you want to see just how many options are available.
    Wal's Avatar
    >I know my spindle has certain collet sizes so standard bits are unlikely to fit.
    Why not - you're using an ER system, aren't you?
    Anyway, as m_c said, there are plenty of options out there - a cursory search brought this up:
    https://www.cadem.com/single-post/cn...l-helix-angles
    Not a bad place to start. As per Chaz's advice - yep, it can be a bit hit and miss with the 2.2kw Chinese spindles - you don't want to go too fast and burn up the drill, but you really don't want to drop much lower than 9krpm as you risk stalling the spindle...
    One thing I would say: make sure you spot drill first..! If you're using standard drill lengths then you can expect a bit of a squeal on the first peck, but that should disappear once the drill gets a bit deeper... Here's a vid of my machine drilling out a section so that I wouldn't have to deep slot (fast forward to about a minute in). I'm sure I could've gone a bit quicker, but you know - when you find something that works you tend to keep it that way..!
    Good luck.
    Wal.
    For general purpose drilling, I'll normally get Cobalt drills. More durable than pure HSS, but typically slightly more brittle (not as brittle as pure carbide though!), and can handle higher speeds than pure HSS (but no where near as high as pure carbide).
    Polished ones for aluminium, and suitably coated ones for steel.
    Key thing is to ensure you are within the speeds/feeds specs for the drill, and as Chaz/Wal say, with Chinese spindles that can be a problem. You'll likely get better results on larger holes by either pre-drilling then milling to size, or just helix milling.
    Spot drilling depends on what you're doing. I generally only use stub drills with split point (or whatever the manufacturer wants to call their self-centring drills), which I'll never spot drill first. However anything I need to use any longer a drill on, I'll generally spot first.
  5. Hello,
    Drilling accurately placed holes is not easy. I strongly suggest screw length bits, the shorter the better, to eliminate deflection. I'm fairly new to cnc and posted a video of my experiences drilling holes here: https://www.youtube.com/playlist?lis...jVPFZmTCBEeF2y
    I should add that I bought an old 3/8" Jacobs chuck off of ebay and a straight 1/2" shaft for it. I chucked it up in a precision collet on the router and damn if it doesn't work perfectly. For drilling operation, no more changing collets or needing collets for every different size. I highly recommend it. I show it in the video I linked to above.
    Cheers, Tyler
    I use a mix of 3mm HSS twist drill in a standard 3mm collet to pilot holes (no spot drill), and then finish on the drill press. Or interpolate holes using a 6mm end mill ideally with a spiral toolpath. Fusion is great for this.
    These end up being very accurate although for bolt clearance holes I often go for bolt nominal diameter plus 0.5 mm to give some allowance in assembly.
    See examples in my videos here:
    4:40 and 10:40
    https://www.youtube.com/watch?v=wqff3IZZWvw
    https://www.youtube.com/edit?o=U&video_id=uwDesJPd6a0
    Good luck.
    Wal.
    Hi Thank you for this.
    Ill take a look into those bits. My spindle is the ER system. The min rpm i can get is 10000.
    The link you sent me takes me to the video edit part on my youtube. Id love to see the video though
    Wal's Avatar
    Quote Originally Posted by dfox1787 View Post
    Ah - I copied link from my creator page - here you go (not that interesting, to be honest..!):
    https://youtu.be/uwDesJPd6a0
    All the best.
    Wal.
  9. Wal, what are you using for coolant and how are you catching it? Would be cool to see a wide shot and overall setup view of your CNC.
    Wal's Avatar
    Quote Originally Posted by wiremonkey View Post
    Here's a link to a handful of pics on an old thread. Added a couple of extras since, but the machine itself remains the same...
    http://www.mycncuk.com/showthread.php?p=55068
    Sent from my HTC One M9 using Tapatalk
  1. Drilling Ø0.2mm holes on aluminium
    By hoezap in forum Metalwork Discussion
    Last Post: 09-04-2016, 06:28 PM
  2. RFQ: Advice for a newbie, please - holes and spheres - 5 axis drilling
    By alixus in forum Projects, Jobs & Requests
    Last Post: 06-05-2015, 02:39 PM
  3. Replies: 2
    Last Post: 16-08-2013, 06:40 PM
  4. Replies: 3
    Last Post: 16-08-2012, 08:50 AM
  5. Replies: 3
    Last Post: 27-09-2011, 11:57 PM
