    Lots of motor drives have an analogue output.
    Can anyone tell me what it does, and what it could be useful for please?
    Many thanks
    Chaz's Avatar
    Quote Originally Posted by Toolman321 View Post
    Many thanks
    Analog output, sounds vague.
    Could be a number of things.
    Likelyhood is that it is a tachometer or encoder, both of which provide some form of voltage to indicate either speed or position.
    How many wires? What does it connect to? If its the rear of the motor, normally this will be for feedback (tacho / encoder).
    Chaz's Avatar
    Many thanks
    Actually, motor drive, sorry, not motor.
    Is this a high or low voltage output? How many wires?
    Its either to get power to the motor or some form of logic / feedback to or from the motor.
    Pics?
    Pics?
    It’s looks to be only 2 wires 0-10v
    Chaz's Avatar
    Output or input?
    If input, it is likely the speed reference.
    If output, it could be a current reading or similar that you can show on a voltmeter or similar.
    Manual of the kit? That will explain ...
    http://www.parker.com/literature/SSD...s/HA389427.pdf
    (Control terminal number 5 output reference 0-10v)
    If it were possible to connect this as a current reference I could use for a load meter that would be great however I can’t find any info in the manual that explains how it would work?
    It actually says
    Control terminal number 5 -- +10V Reference -- Analogue output, +10v Reference for speed and current set points
    It's the 10v you connect to one end of a pot, with the other end to 0v and then use the pot variable output to the analogue input for a speed control knob.
    There may be other stuff you can use it for but you have to read the whole manual and see what the relevant Parameter settings configure.
  8. The Following User Says Thank You to magicniner For This Useful Post:
  1. FOR SALE: Parts For Sale - Servo Drives, Controller, 3Kw Motor, Transformers
    By MrBurns in forum Items For Sale
    Last Post: 27-01-2017, 06:13 PM
  2. Drives without steppers
    By Wobblycogs in forum Gantry/Router Machines & Building
    Last Post: 27-03-2014, 01:07 PM
  3. Replies: 9
    Last Post: 21-02-2014, 09:57 PM
  4. Stepper Drives
    By GTJim in forum Marketplace Discussion
    Last Post: 05-04-2013, 12:05 PM
  5. Help with 3 axis CNC motor and drives
    By domagoj55 in forum General Electronics
    Last Post: 04-03-2013, 12:51 PM
