  1. #4
    Lives in East Lothian, United Kingdom. Last Activity: 17 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Does it actually pause, or does it continue to retract very slowly?
    There is a 'glitch' with turning, external motion controllers, and certain versions of Mach3, where at the end of the threading move when things should switch from mm/rev to mm/min, it changes mode but doesn't update the feedrate. So if you were doing say a 1mm pitch thread, it'll switch to 1mm/min and retract at that speed until the retract move is done, at which point the feedrate will update to the correct rate.
    It's a known problem with later versions of Mach3 that CS-Labs can't do a tapered lead out, and you have to have a groove at the end of the thread. I've also witnessed it when using Mach 3 with my KFlop controlled lathe.
  2. The Following User Says Thank You to m_c For This Useful Post:
  1. ACP Problem
    By RYANB123 in forum AXYZ Routers
    Last Post: 01-11-2017, 07:13 PM
  2. kx 1 problem
    By bab160 in forum Sieg Milling Machines
    Last Post: 31-07-2016, 11:37 AM
  3. help with problem please
    By martin54 in forum General Electronics
    Last Post: 27-08-2014, 09:43 AM
  4. Problem with X
    By gorbo in forum General Discussion
    Last Post: 24-02-2011, 05:33 AM
  5. Z Problem
    By airwolf in forum Machine Discussion
    Last Post: 10-11-2009, 08:08 AM
