    OK
    If you have had a look @ Boyans yellow machine this is steel construction and i do believe he was making the construction files free to forum members, there are files for a lot of the components that can be plasma cut. LINK IN THREAD
    Niel's vertical machine http://www.mycncuk.com/threads/2148-...ers-and-Planes.
    Not sure if JAZZCNC Dean is snowed under with work but i would drop him a PM and have a crack he should be able to give you an idea of what can done and a good estimate of the cost if he is unable to help @ this time.
    Steel frame is going to work out cheaper if you can turn your hand to a bit of welding.
    hope that helps.
    Regards
    MIKE
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. SOLD: Clear out time!
    Last Post: 24-03-2018, 11:41 AM
  3. precision ground angle plates - quality brands?
    By dsc in forum Tool & Tooling Technology
    Last Post: 30-01-2015, 06:14 PM
  4. FOR SALE: Connectors, Heat sinks and other parts clear out....
    Last Post: 09-02-2011, 06:00 PM
  5. FOR SALE: 48V Power Supply - The clear-out continues
    Last Post: 09-02-2011, 02:14 PM
