    Chaz's Avatar
    Looking to build a frame around my lathe, steel is cheaper than Alu. What thickness would suffice to make a cover of sorts for my Lathe? Trying to enclose it as much as possible to stop coolant spray / mess.
    Lives in East Lothian, United Kingdom. Last Activity: 5 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    It'll depend on how much you want to brace it to stop vibrations.
    0.6/0.8mm would need a reasonable amount of bracing (or strategic folds/ribs/kinks) to give it strength on large flat areas and avoid it resonating.
    1mm shouldn't need much reinforcing except for large flat panels and around openings.
    1.2mm shouldn't need any reinforcing.
    Off course, the thicker you use, the more effort it takes to cut/bend, and weight can quickly add up, so it's a bit of a trade off.
    Ideally I'd probably use 0.8 for large simple panels with a few ribs to save weight, then 1/1.2 for any with openings/doors with suitable folds to provide a strong structure. In practice, I'd likely use whatever I have lying around at the time.
    Chaz's Avatar
    Thanks. In steel or alu or dont mind (based on what you have)?
    Steel.
    I've not got the equipment, or the motivation to deal with welding aluminium.
  5. The Following User Says Thank You to m_c For This Useful Post:
  1. material
    By bobjer in forum Classified Ads, Buy, Sell & Swap
    Last Post: 12-11-2017, 08:19 AM
  2. Material for lithophane's
    By Mad Professor in forum General Discussion
    Last Post: 30-05-2016, 09:44 PM
  3. Knowing a Cutters Material?
    By Tenson in forum Tool & Tooling Technology
    Last Post: 26-10-2015, 04:22 PM
  4. Material for machining
    Last Post: 14-04-2015, 06:20 PM
  5. Holding down sheet material.
    By jcb121 in forum Machine Discussion
    Last Post: 03-07-2013, 12:11 AM
