  1. Click image for larger version.
Name:	Steel X mockup v5.png
    So, here is my current plan for the X beam, 2" x 6" x 3/16" steel beam with linear rails. I'll weld at least .25" thick plate onto the ends for mounting to the gantries. Maybe thicker? Not sure if it's necessary, will just add more weight.
    Over on the Openbuilds forum, M90Ranger suggested I split up the rails and use a design like this: Click image for larger version.
ID:	24452 Certainly two .25" wall 2" or 3" square tubing would be cheaper than the single 2" x 6" I purchased. Somehow I like the overall feel of the single rectangular tube. Which do you think would be more rigid?
    Check out my DIY CNC trials and tribulation videos on YouTube: https://youtu.be/SwHb75_GWwM
  1. Shallow channel/Contour
    By dfox1787 in forum Fusion 360
    Last Post: 08-05-2018, 11:49 AM
  2. Beam choice
    By idegraaf in forum Gantry/Router Machines & Building
    Last Post: 22-03-2018, 07:38 PM
  3. BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
    By Slixxor in forum DIY Router Build Logs
    Last Post: 29-12-2016, 02:57 AM
  4. DeskProto 3D cam software, forum support added!
    By Lee Roberts in forum DeskProto
    Last Post: 27-01-2014, 03:21 PM
  5. He's added a fourth axis
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 01-08-2010, 08:33 PM
