  1. OK, so I'm solid on using the 2" x 6" steel tube for the X beam! I have a few more questions for you good folks.
    - 1/4" inch steel plates for the end caps on the beam? Or should I go thicker? 1/2"?
    - 20mm round supported rails and bearings ~$80, or spend the extra dough and get linear rails and bearings ~$240!
    The other factor on the square rails is that I'll have to have the steel beam milled, which will probably cost $200 or more, whereas the supported round rail is far more forgiving when it comes to alignment. The rectangular steel tube has a round crest to it, but it is fairly consistent along the length of the beam. I'm thinking that I can screw the supported round rails right to the beam, maybe a little shim stock if necessary, easy peasy.
ID:	24471 VS. Click image for larger version.
    I'd love to hear your thoughts on these two issues.
    Cheers!
    Check out my DIY CNC trials and tribulation videos on YouTube: https://youtu.be/SwHb75_GWwM
  1. Shallow channel/Contour
    By dfox1787 in forum Fusion 360
    Last Post: 08-05-2018, 11:49 AM
  2. Beam choice
    By idegraaf in forum Gantry/Router Machines & Building
    Last Post: 22-03-2018, 07:38 PM
  3. BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
    By Slixxor in forum DIY Router Build Logs
    Last Post: 29-12-2016, 02:57 AM
  4. DeskProto 3D cam software, forum support added!
    By Lee Roberts in forum DeskProto
    Last Post: 27-01-2014, 03:21 PM
  5. He's added a fourth axis
    By GeorgeD in forum Gantry/Router Machines & Building
    Last Post: 01-08-2010, 08:33 PM
