30-05-2018 #3
This would be classed as a Semi-Business machine build. I'm not concerned about the rapids speed or volume this machine can do but its consistent accuracy.
The use of the machine is to carve 3D protype models in milling composite, wood and foamboard. It'll actually be an XYZ with a AB head on a deep Z axis. It also needs to carve positive and negative forms as molds. I'm expecting to be able to switch the AB head out to put in a regular 2.2kw spindle for milling some smaller aluminium parts.Last edited by marbles; 30-05-2018 at 05:02 PM.
WANTED: Conqueror Design stepper driver or stepper conversion board
By pistolknight in forum Items WantedReplies: 1Last Post: 25-05-2019, 11:57 AM -
Which stepper driver is a good alternative to Gecho 540
By marbles in forum Gantry/Router Machines & BuildingReplies: 1Last Post: 30-05-2018, 04:03 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
Stepper Motor Driver - cheap similar to ArcEuro 4.2A Bi-Polar Stepper Motor Driver
By craynerd in forum Motor Drivers & ControllersReplies: 1Last Post: 16-03-2014, 07:29 PM -
Routoutcnc driver says good bye !!!
By Lee Roberts in forum Motor Drivers & ControllersReplies: 3Last Post: 13-05-2009, 08:20 PM
