Thread: Mk2 extrusion router
05-06-2018 #2
That's the reason for me asking on here regarding extrusion size as I need to know that before I proceed onto the whole drawing up in fusion. An image here to show what I mean by push in on the ends. http://i.imgur.com/yajSuNI.jpg
15-06-2018 #3
Hi RobC
I don't think you need to mill pockets in the end-plates for your router frame. See my build here. Just use sturdy section extrusion (I used 80x40 heavy gauge 4kg/m ) with extra aluminum strips under the supported round rail. It is plenty rigid enough when bolted up with M8 screws into the ends of the extrusion. Like others have said do a CAD drawing so you can be clear in your thinking and express clearly to others what you are trying to achieve. A picture always tells a thousand words....
Regard
Michael
16-06-2018 #4
Hello Michael, I'm still trying to decide really as the extrusion from mcmastercarr in fusion360 is not the dimensions it says it is as its 0.200mm out and it's messing up my designs so I think I'll have to order the extrusion and then measure it to check then go off that figure in cad.
It's not too different from my current build what you built, just slightly different gantry design.
Rob
16-06-2018 #5
Rob
I would use a British extrusion drawing (or metric) as it might be different than from the USA
try here https://www.motedis.co.uk/shop/Slot-...91_999994.html..Clive
Aluminium Extrusion Router Build
By NFryer in forum Gantry/Router Machines & BuildingReplies: 76Last Post: 03-07-2019, 07:59 PM -
NEW MEMBER: where to buy aluminum extrusion
By troyboy1 in forum New Member IntroductionsReplies: 3Last Post: 21-07-2014, 01:52 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
WANTED: Ali Extrusion anyone?
By D-man in forum Items WantedReplies: 0Last Post: 08-11-2010, 11:01 PM -
extrusion construction
By CNCBlug in forum General DiscussionReplies: 12Last Post: 03-01-2010, 12:13 AM
