View Poll Results: Which CNC Bridge is the best ?
Voters
0. You may not vote on this poll
  • 1 st design
    0 0%
  • 2nd design
    0 0%
  • 3th design
    0 0%
Page 2 of 2 FirstFirst 12
    After pippin recommendation I changed X axis design.
    After changing double linear on each X axis to one linear rail, mass of bed frame and bridge are changed.
    Double linear rail type : RGW35CC - 35 mm width rail - 100 mm width linear carriage block
    One linear rail type : RGW45CC - 45 mm width rail - 100 mm width linear carriage block
    6 linear carriage bearings canceled, 2 piece of 4m length linear rail canceled.
    With the reduction of steel profiles, there is approximately total 1.500 - 2.000 USD cost reduction due to one rail design.
    Old Mass :
    Bridge : 1.200 kg
    Bed Frame : 4.800 kg
    New Mass :
    Bridge : 1.100 kg
    Bed Frame : 3.950 kg
    I need help about X axis drive. I think both X axis and Z axis should be rack&pinion design instead of ball screw.
    At X axis ball screw is way above linear rail I didnt like it, and rack&inion will get the ram closer to the saddle for Z axis.
    Any ideas.
Name:	X-1 rail-pers.jpg
ID:	24391   Click image for larger version.
Name:	X-1 rail-front.jpg
  1. CNC Router to cut glass, marble, advice on which machine is best to buy please
    By barrykavanagh365 in forum Gantry/Router Machines & Building
    Last Post: 05-03-2019, 08:37 AM
  2. Using a metal cutting burr with a router...?
    By noyloj in forum Metalwork Discussion
    Last Post: 10-01-2017, 12:44 AM
  3. 4 axis machining software
    By edgas10 in forum CAD & CAM Software
    Last Post: 17-02-2016, 08:00 PM
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. 4th Axis CAM Software Multi Sided Machining
    By alan2525 in forum Computer Software
    Last Post: 18-02-2010, 12:44 AM
