View Poll Results: Which CNC Bridge is the best ?
Voters
0. You may not vote on this poll
  • 1 st design
    0 0%
  • 2nd design
    0 0%
  • 3th design
    0 0%
    Well i cant see attachments with my cellphone, uploaded from my pc!?
    Quote Originally Posted by Halbmond View Post
    Pictures are OK on my phone.
    Looks like an interesting project. On the Y axis will you be able to weld all those pieces and get flat and parallel surfaces for the carriages which connect to the Z axis?
    Indeed it is interesting project and very good static and dynamic properties the bridge structure has.
    We have plenty of machining centers which is capable of machining this big structures. After stress relieving we will machine all of the rail bottom plates, carriage connection plates, bearing block connection plates.
    We are going to machine 4 surfaces of the bridge , one by one at a horizontal bohrwerk cnc .It will make the surface flat and paralell to the corresponding surface within tolerance of (+- 0.05)
    I would be glad to get any recommendation or comment /critics, especially for the bed frame.
    I can reduce the footing quantity from 4 to 3 on each side of bed frame and place triangle support plates between footing and linear rail profile.
Name:	Thirth Bridge-Ram Top-1.jpg
    You may see rail lock and carriage lock units at every axis.
Name:	Linear rail locks.jpg
ID:	24358   Click image for larger version.
Name:	Carriage Locks.jpg
    Here are self leveling chock and my standard leveling blocks for bed frame foots.
Name:	Self leveling chock.jpg
ID:	24367   Click image for larger version.
Name:	CNC foot-0.jpg
  1. CNC Router to cut glass, marble, advice on which machine is best to buy please
    By barrykavanagh365 in forum Gantry/Router Machines & Building
    Last Post: 05-03-2019, 08:37 AM
  2. Using a metal cutting burr with a router...?
    By noyloj in forum Metalwork Discussion
    Last Post: 10-01-2017, 12:44 AM
  3. 4 axis machining software
    By edgas10 in forum CAD & CAM Software
    Last Post: 17-02-2016, 08:00 PM
  4. Precision metal processing (3 axis, 5 axis, 7 axis) OEM
    By 7AxisCNC in forum Manufacturer News
    Last Post: 17-05-2011, 02:04 PM
  5. 4th Axis CAM Software Multi Sided Machining
    By alan2525 in forum Computer Software
    Last Post: 18-02-2010, 12:44 AM
