    Retro fit core drill for motorised z axis, suggestions.
    I have a new project and I want to cut some cores out of stone so I'm thinking of getting a, not so expensive bench core drill, and retro fitting the z axis so I can be cutting the cores slowly but efficiently and doing other things at the same time.
    I'm thinking a pulley and motor may slip .. unless say I use a toothed car cam wheel type setup ? Direct stepper motor may be a bit to large to produce the torque ? Not sure I'm no expert :)
    Example pic
    its basically a very small version of this below which i think is really cool lol :)
    Ralph Waldo Emerson
    Do you need fixed feed speed or fixed cutting pressure?
    I was thinking fixed cutting pressure , cutting speed would depend on material and also help tool life I think.. not sure lol
    I had thought of putting a wide pulley on and fixed weight on a chain, seen this done for other things
    Ralph Waldo Emerson
    Quote Originally Posted by Fivetide View Post
    My thoughts too, if fixed force.
    For fixed speed a stepper, stepper driver, variable frequency pulse generator and toothed pulleys & belts.
  5. The Following User Says Thank You to magicniner For This Useful Post:
  6. #5
    Yes agreed.. I think ill try that.. keep it simple rule. Thanks magicniner
    Ralph Waldo Emerson
  1. Triac - old version, retro fitted servos
    By Benja in forum Classified Ads, Buy, Sell & Swap
    Last Post: 23-02-2018, 12:28 PM
  2. Retro fitting an old Dahlgren engraver.
    By millietess in forum Motor Drivers & Controllers
    Last Post: 29-11-2014, 09:41 PM
  3. FOR SALE: Axminster RF40 mill/drill 3 axis dro, Base and extras
    Last Post: 04-08-2013, 10:30 PM
  4. Stay with Gearbox or retro fit DC motor etc;
    By manofgresley in forum Linear & Rotary Motion
    Last Post: 06-04-2013, 05:17 PM
  5. suggested equipment to retro fit a 6040 yoocnc
    By madprof1 in forum Milling Machines, Builds & Conversions
    Last Post: 03-12-2012, 09:52 PM
