    See new drawing.
    Regards the Limit switches I just want to make you aware that can use just one switch that moves with the axis and sense targets at each end of travel. This lowers the number of switches required to one for each axis and less wiring required which means lower chance of faults.
    Each switch can also share the homing and limit switch dutys.
    .If want to use this method then wire limits like in my first drawing. Set Limits and homes for each axis to same pin number in mach3 and then go to general config and turn off Home SW safety option.
    In this new drawing the VFD is stopped if E-stop occurs. Also VFD will tell the controller if VFD faults. For this to work you will need to enable Spindle fault detection and set the Input # used.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    Jazz thank you again for your time and dedication !!!
    sorry to bother you once again ... I have a homemade cnc with electronic Leadshine HBS86H drivers and 86HBM80-01-1000 engines with encoders and the IPM controller as mentioned before.
    I have everything connected X-Y-Z-A
    I configure everything according to your video in youtuve
    (https://www.youtube.com/watch?v=mNZ4wOTg8jE&t=35s)
    axes-------------------------------------IPM pins
    X channel 0----------------------------- 1-2 14-15
    Y channel 1----------------------------- 3-4 16-17
    Z channel 2----------------------------- 5-6 18-19
    A channel 3 (slave of Y)----------------- 7-8 20-21
    when feeding the drivers everything perfect, I move with the keyboard the X and Z axes
    but I try to move the Y-A axes and the alarm of both drivers goes off
    I manually move the axes without any problem
    I am doing something wrong ? What could the alarm be triggered?
    Thanks for reading and helping in my consultations
    Greetings Jorge
    Hi jorge,
    Ok well first let me say that the video wasn't done to show anyone how to wire drives etc, it was done just to show that slaving works and it's shortfalls. Also if you have understood my Yorkshire accent then very well done because people only 30km away usually struggle. . . Lol
    Why you are having problems could be one of several reasons.
    First check motor outputs are wired correctly. See below.
    CH0 Dir (+) = 1 Dir (-) = 14 Step (+) = 2 Step (-) = 15
    CH1 Dir (+) = 3 Dir (-) = 16 step (+) = 4 step (-) = 17
    CH2 Dir (+) = 5 Dir (-) = 18 step (+) = 6 step (-) = 19
    CH3 Dir (+) = 7 Dir (-) = 20 step (+) = 8 step (-) = 21
    Next could be Motor phase wiring is wrong so check the motor wires are correct. The sequence and frequency of flashing LED lights should tell you fault code. Check the manual for fault codes.
    Next check the Current settings on the drives just in case you have them set to very low current setting and the motors are stalling, the fault codes should tell you this.
    If this doesn't work then take pictures of the wiring or make video and post here.
  5. #4
    Hello JAZZ the red LED flashes 7 times in a row and the photo indicates the error but I do not understand what it can be?
    Thank you !!!
    regards
  6. #5
    Quote Originally Posted by SaporeCNC View Post
    Thank you !!!
    regards
    This indicates it's an encoder error so check the encoder wires are correct.
  7. #6
    Friend all solved the shafts move perfect, it was an encoder cable that was disconnected !!!
    in the next few days I connect the e-stop, the end of the race and the VFD ... any doubts you may have and you can be disturbed again with some other question
    from now I appreciate your dedication and wisdom in answering my questions and solving the problems I had due to lack of experience in the construction of my cnc router
    again thanks for everything
    Greetings Jorge
  8. #7
    Hello everyone
    I mention my problem I have connected the spindle vfd and when I turn with the mach3 it only travels
    at 12000 rpm and I can not vary its speed ...
    Anyone know what might be happening ??
    Thank you
    regards
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Mach3 Showing Emergency Triggered
    By Cube3 in forum Artsoft Mach (3 & 4)
    Last Post: 03-12-2017, 06:59 PM
  3. Long shot - emergency lathing!
    By Rogue in forum General Discussion
    Last Post: 26-06-2015, 01:44 PM
  4. Sieg KX1 & Mach3 won't come out of emergency reset
    By lateAtNight in forum Gantry/Router Machines & Building
    Last Post: 19-06-2015, 06:37 PM
  5. Connect 121 revamp
    By Miller in forum Conect Lathes
    Last Post: 16-10-2014, 05:42 PM
