    Friend all solved the shafts move perfect, it was an encoder cable that was disconnected !!!
    in the next few days I connect the e-stop, the end of the race and the VFD ... any doubts you may have and you can be disturbed again with some other question
    from now I appreciate your dedication and wisdom in answering my questions and solving the problems I had due to lack of experience in the construction of my cnc router
    again thanks for everything
    Greetings Jorge
    Hello everyone
    I mention my problem I have connected the spindle vfd and when I turn with the mach3 it only travels
    at 12000 rpm and I can not vary its speed ...
    Anyone know what might be happening ??
    Thank you
    regards
    Quote Originally Posted by SaporeCNC View Post
    Hello everyone
    Thank you
    regards
    Can you give details of how you have connected it and have you changed any parameters in the VFD
    Hello everyone
    Thank you
    regards
    First have you enabled the Spindle and set Analog output pin in the plug-in. Until this is done you won't be able to control the speed.
    In the plug-in there is also a setting for Acceleration/deceleration set this to 24000.
    You will also need to set the pulley speeds in Mach3 and setup the spindle in ports & pins.
    Also check the VFD accepts 0-10v and not 0-5v. Some VFD's can be set to use either.
    Hello, thank you for your time
    I pass the parameters that you enter in the VFD and I also add an attachment with the wiring of the VDF HY 3Kw 220v to the CSmioIPM and the data that you enter in the Mach3
    I hope you can guide me and see why I turn the engine only at 12000 rpm
    thank you very much
    regards
    Pd001 - 1
    PD002 - 1
    PD003 - 300 (frecuencia predeterminada)
    PD004 - 300 (frecuencia nominal)
    PD005 - 300 (frecuencia de gama alta)
    PD008 - 220 (voltaje de gama alta)
    PD009 - 15 (voltaje del extremo medio)
    PD010 - 8 (voltaje de baja tensión)
    PD011 - 200 (frecuencia mínima permitida)
    PD014 - 4 (tiempo de aceleración)
    PD015 - 6 (tiempo de desaceleración)
    PD046 - 9
    PD052 - 2
    PD070 - 0 (entrada de control de velocidad)
    PD072 - 300 (frecuencia alta)
    PD141 - 220 (Voltaje nominal del husillo)
    PD142 - 8.6 (Amperaje nominal del husillo)
    PD143 - 2 (Número de polos)
    PD144 - 3000
    gracias !!!
Name:	VDF a CSMIO IPM a Mach3.jpg
    Pd001 - 1
    PD002 - 1
    PD046 - 9
    PD052 - 2
    PD144 - 3000
    check PD002 If it is set to one then check the jumper next to the screw terminals that you have to set. If it is on the right pair , the control is via the front knob. If it is on the left pair the control is via an external pot connected to the screw terminals.
    PD003, 4 , 5 I think should be 400
    PD142 is the current rating for the spindle if its 3Kw try about 13 2.2Kw would be about 10
    Hello, thanks for the answer
    I still have no result, some other advice!
    regards
    regards
    Ok then, what how have you wired it? have you changed the parameters in the VFD. No one has a crystal ball!!
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Mach3 Showing Emergency Triggered
    By Cube3 in forum Artsoft Mach (3 & 4)
    Last Post: 03-12-2017, 06:59 PM
  3. Long shot - emergency lathing!
    By Rogue in forum General Discussion
    Last Post: 26-06-2015, 01:44 PM
  4. Sieg KX1 & Mach3 won't come out of emergency reset
    By lateAtNight in forum Gantry/Router Machines & Building
    Last Post: 19-06-2015, 06:37 PM
  5. Connect 121 revamp
    By Miller in forum Conect Lathes
    Last Post: 16-10-2014, 05:42 PM
