    Hello, thank you for your time
    I pass the parameters that you enter in the VFD and I also add an attachment with the wiring of the VDF HY 3Kw 220v to the CSmioIPM and the data that you enter in the Mach3
    I hope you can guide me and see why I turn the engine only at 12000 rpm
    thank you very much
    regards
    Pd001 - 1
    PD002 - 1
    PD003 - 300 (frecuencia predeterminada)
    PD004 - 300 (frecuencia nominal)
    PD005 - 300 (frecuencia de gama alta)
    PD008 - 220 (voltaje de gama alta)
    PD009 - 15 (voltaje del extremo medio)
    PD010 - 8 (voltaje de baja tensión)
    PD011 - 200 (frecuencia mínima permitida)
    PD014 - 4 (tiempo de aceleración)
    PD015 - 6 (tiempo de desaceleración)
    PD046 - 9
    PD052 - 2
    PD070 - 0 (entrada de control de velocidad)
    PD072 - 300 (frecuencia alta)
    PD141 - 220 (Voltaje nominal del husillo)
    PD142 - 8.6 (Amperaje nominal del husillo)
    PD143 - 2 (Número de polos)
    PD144 - 3000
    gracias !!!
Name:	VDF a CSMIO IPM a Mach3.jpg
    Pd001 - 1
    PD002 - 1
    PD046 - 9
    PD052 - 2
    PD144 - 3000
    check PD002 If it is set to one then check the jumper next to the screw terminals that you have to set. If it is on the right pair , the control is via the front knob. If it is on the left pair the control is via an external pot connected to the screw terminals.
    PD003, 4 , 5 I think should be 400
    PD142 is the current rating for the spindle if its 3Kw try about 13 2.2Kw would be about 10
    Hello, thanks for the answer
    I still have no result, some other advice!
    regards
    Quote Originally Posted by SaporeCNC View Post
    regards
    Ok then, what how have you wired it? have you changed the parameters in the VFD. No one has a crystal ball!!
    hello if you change them and nothing like the same always rotates at the same speed ...
    in a previous post is the scheme of the connection and the parameters you enter in Mach 3
  1. How to connect 2.2KW Inverter VFD?
    By Tenson in forum Spindles & Drive Motors
    Last Post: 13-07-2020, 01:47 PM
  2. Mach3 Showing Emergency Triggered
    By Cube3 in forum Artsoft Mach (3 & 4)
    Last Post: 03-12-2017, 06:59 PM
  3. Long shot - emergency lathing!
    By Rogue in forum General Discussion
    Last Post: 26-06-2015, 01:44 PM
  4. Sieg KX1 & Mach3 won't come out of emergency reset
    By lateAtNight in forum Gantry/Router Machines & Building
    Last Post: 19-06-2015, 06:37 PM
  5. Connect 121 revamp
    By Miller in forum Conect Lathes
    Last Post: 16-10-2014, 05:42 PM
