    dsc's Avatar
    Lives in Lincoln, United Kingdom. Last Activity: 17-06-2020 Has been a member for 9-10 years. Has a total post count of 252. Received thanks 1 times, giving thanks to others 11 times.
    Just a quick question for all the electronic brainiacs out there who know a lot about power supplies.
    I'm currently using a Leadshine SPS705 (68vdc) unregulated power supply which seems to be on it's last legs. Output voltage is fluctuating really badly, going from zero to 50ishV and back down, often failing to even reach 50vdc and slumping down to barely 20ish vdc. No idea what failed or why it failed, it is only used 2-3 times a day and only for 10-15sec, then off all the time, has a single stepper motor on it with a DM856 controller.
    Plan of action is to check all the diodes in the bridge and possibly try to repair or get a new unit, but it will take around 20min to get the current unit out of the machine so I wanted to double check what it might be before trying to fix.
    Rgds,
    T.
    seeing its an unregulated switch mode supply
    it could be a fault with the stepper motor or driver is causing the supply to protect its self
    if you do open the power supply
    you will find the bridge rectifier is connected across live & neutral watch out - the large capacitor may take a while to discharge the 340V DC it has across it when the mains supply is on
    John
    PS
    do you have a 60 or 100W GLS bulb you can use as a dummy load to test the power supply ???
    *GLS bulbs are old fashioned incandescent light bulbs with the tungsten filament the greens don't like
    dsc's Avatar
    Thanks for your reply John and for the tips on the cap charge!
    Indeed it might be a faulty controller / stepper, I simply jumped to the conclusion it's the PSU as the voltage was fluctuating so much, first only moving between 40-60VDC, then slowly drifting more and more towards lower voltages, now only moving between 0VDC and 20ish VDC. Oddly enough the stepper still works, not straight away after switching the power on, but if you leave it for a few minutes the voltage must creep above 20VDC as this is the absolute minimum the DM856 can work.
    The PSU is overspec'd for the stepper set up as it stands, I'm using a SY57STH56-3008B Nema 23 stepper and all it does is move a few steps each way, a few times a day, then the whole lot is powered off. There's also an additional circuit added on the output of the PSU which is a Zener diode used to drop the voltage from 68VDC to 24VDC which can then be used to drive a panel mounted indicator, see here:
    http://www.mycncuk.com/threads/7948-...s-and-high-VDC
    No idea if this is somehow affecting the PSU over time and causing a failure? Another thing which happens fairly often is powering the kit on / off, typically 2-3 times a day, sometimes more often. There is a servo with a controller mounted on the same AC supply (it's got an AC filter mounted to reduce noise when it comes on / off), but it has it's own MCB, the SPS705 is powered via an additional switch, so even if there was some back current from the servo controller startup, the additional switch should protect the SPS705 (or so I think).
    Regards,
    Tom
    EDIT: not got any GLS bulbs at the moment but I can order some I reckon (assuming they are still available)
    the last GLS bulbs I bought was from a local discount store
    https://www.bmstores.co.uk/search?q=light+bulb
    but i see the nearest the have now are 240v Halogen Bulbs
    https://www.bmstores.co.uk/products/...ulb-3pk-322405
    ebay & amazon have them
    RS Components have these
    https://uk.rs-online.com/web/p/gls-i...bulbs/0604624/
    I guess Rough Service Lamps for industry are excluded from the ban
    the first time I used a GLS bulb as a dummy load was when I built the Forgestone 500 TV in 1982
Name:	Forgestone colour developments 500 series ctv.jpg
    the 143V DC switch mode power supply had to be set up correctly before it was connected to the rest of the receiver
    to avoid the EHT going over 24KV and the CRT giving you an X-ray over dose
    John
    Last edited by john swift; 20-06-2018 at 04:38 PM. Reason: add ref to forgestone tv kit
  5. The Following User Says Thank You to john swift For This Useful Post:
  6. #5
    You can still get the 100W Halogen filament strip lights they use in work lights at places like Toolstation. Would these be OK? It is only a resistive load you need. John - What do you think ?
  7. The Following User Says Thank You to cropwell For This Useful Post:
  8. #6
    I am not sure how the cold resistance of a Halogen bulb compares with that of a GLS bulb
    As long as the cold resistance of the halogen lamp is not too low for the power supply to start
    the Halogen lamp should be OK
    cold the 240V 100W GLS bulb about 43 ohms
    to setup the Forgstone TV Kit
    the GLS bulb was used as a low cost alternative to a
    600 ohm 100w resistor
    since then I have use the bulbs to test other things like the speed controls used in a Clarke CL300M lathe
    https://www.model-engineer.co.uk/for...s.asp?th=38809
    John
  1. Which power supply to use
    By Palletlad in forum General Electronics
    Last Post: 13-04-2018, 05:34 PM
  2. Power supply help
    By Davo242 in forum General Electronics
    Last Post: 07-01-2016, 01:00 AM
  3. FOR SALE: power supply
    Last Post: 14-09-2014, 03:19 PM
  4. Replies: 0
  5. FOR SALE: 50V 20A Power supply
    Last Post: 30-05-2011, 11:01 PM
