Thread: CNC Spindle synchronization
What controller are you using, as that will dictate what options are available?
Encoders/slot sensors are normally mounted on the spindle which a motor change shouldn't affect, and Mach must be seeing something if it's attempting a threading move (it should pause until it sees a suitable/stable spindle speed before moving).Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
14-06-2018 #2
Guys still trying to get my head around what I have got and what I have not. - Mach diagnostics do not show an active encoder light.
The speed is apparently being displayed, but checking with optical tacho, 200rpm set and 208rpm actual given on Mach3 screen read out on the tacho at 240. So not too accurate.
I guess I will buy a new encoder head and make a Mach3 single slot disk to run on the back of the spindle.
Any suggestions for a UK encoder purchase appreciated.
14-06-2018 #3
14-06-2018 #4
Chaz - Thanks. Did you use the rotary encoder?
14-06-2018 #5
14-06-2018 #6
Chaz THanks again. Has anyone connected such a rotary encoder to Mach 3 please?
14-06-2018 #7
14-06-2018 #8
One thing to watch out for is that if your new motor is not controlled from M3, M3 won't know if it's running. You need to start the motor AND press the "Spindle" button.
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
CNC Spindle Repair and Spindle Replacement for any Machine of any Manufacturer
By spindeldoctor in forum Manufacturer NewsReplies: 0Last Post: 13-11-2013, 07:50 PM -
Spindle lock mechanism for 2.2kW china spindle
By Jonathan in forum Generic Chinese SpindlesReplies: 8Last Post: 13-08-2012, 08:39 PM -
DIY Spindle - What type of bearings are best suited for a spindle.
By 8iggles in forum Spindles & Drive MotorsReplies: 18Last Post: 09-02-2011, 10:15 PM
