  1. OK I think I've learnt something here...
    So a Slocombe, aka, centre drill is really intended to create holes for a shaft centre support for further machining on a lathe, but because of their narrow tip often get used instead of...
    spotting drills... which have a precisely ground 90degree tip and are used to create a pilot hole for a bigger jobbing or twist drill.
    Stub drills are conventional but shorter stiffer drills that are less likely to wobble or mistrack and can be used as spotting drills to start a twist or jobbing drill for deeper holes...
    Did I get that right? Stub drills seem to be cheap (Dormer ones are £1 - £5), while spotting drills seem to be expensive (£10 - £40)
    So what is the best practice, say, to:
    drill a 6mm dia 15mm deep hole centrally in a 20mm steel shaft on the lathe?
    drill a 6mm dia 30mm deep hole in a 50mm piece of ali in the mill?
    assuming ownership of a complete set of 1 - 10mm in .1mm HSS twist drills...
    I know I'm a bit fuddy-duddy and old-hat with my Slocombes but I do like them for starting a Jobber.
    You get that 60 degree cone to align the bit PLUS a perfectly concentric pilot hole to clear the awkward drill centre.
    The Jobber goes in real easy to the bottom of the pilot by which time you have a much better hold on centre.
    I'm not going to argue the why's and wherefore's, but I think they are neat
  1. SBR16UU Centre hole.
    By cambesol in forum Rails, Guideways & Bearings
    Last Post: 25-11-2013, 05:39 PM
  2. Small footprint turning centre
    By Hellfire in forum Marketplace Discussion
    Last Post: 28-08-2013, 10:13 PM
  3. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
  4. Turning centre retrofit help/project on a Mazak/Yamazaki
    By spluppit in forum Mazak, Yamazaki Lathes
    Last Post: 13-11-2010, 01:43 AM
  5. Broken centre drill recovery
    By Robin Hewitt in forum Tool & Tooling Technology
    Last Post: 25-01-2010, 10:53 PM
