Hi Clive,
I did what you said with the shieldings and it works. Almost perfect. The only thing left, is that my pc behaves a bit weird sometimes, for a few seconds, when I turn off the vfd, weird meaning the cursor is dancing on my screen for apx 10-15 sec and them returns to normal.
I'll try to use a ferrite ring as you mentioned, for the vfd mains, as that cable is not shielded.
The motors are working fine so far.
So THANK YOU!
I.ll keep in mind your suggestion about a double ballscrew drive and one motor, if any issues will come up with this design. This change on it.s own takes a long time, as I.ll need to build and buy a quite a few extra parts to make it work, so maybe wishful thinking might work this time and function ok as it is.
Even if I have the hardware to add two motors, I.ll avoid this method, as in this last problem I had with noise, the motors were spinning in random ways, not to mention other possible hardware failures which might get them out of sync, and it looks problematic to a point of damaging some expensive parts.
A 5 feet belt might cause some trouble as well, but with enough patience I think I can make it work.
So once again thank you.
As for the second issue, with the limit switches, any idea what I.m doing wrong?
All 6 limits are wired in pairs of two, in series like in the photo, NC, where one wire goes into a numbered pin, and the other into the ground pin. P10 to 12 being used in this case for limits. How should I set this in mach3?
I.m new to this forum and not sure what.s the proper way to post questions. Should I separate the questions and post them in certain categories or ask all the quesions in one thread?
