04-11-2018 #11
I use inductive proximity sensors for home switching, but a micro-switch for limit like this
The inductive sensor triggers off the aluminium of the gantry, but the micro-switch is tripped by a plastic wedge, which allows me to adjust the trip point.
Separate pictures as I can not move the gantry at the moment as I am installing a new mains switch panel for the computers and CNC.
There is one lesson I learned early on - do not have the proximity switch triggered by movement axially toward the switch, once you crush the end it is f***ed (rendered inoperative permanently), make the movement across the face of the switch. If you mount the switch on the gantry, you will only need one switch to sense at both ends of travel, by putting metal targets (preferably ferrous) at the appropriate places.Last edited by cropwell; 04-11-2018 at 01:02 AM.
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
