06-12-2018 #11
Rob. I still don.t get why you seem so happy about the Kress router. I assume yoga might be your secret. :))
Hi Neale.
Truth be told, for the y axis I kind of hoped for the best in the setup. I tried some techniques I found online to align the rails, and the ballscrew, but it seemed to not work so well as advertised, so in the end, I just did a feel run, like aligned one end of a rail, than bolted that, that the other one, and used some shims to adjust any issue, and when it felt like it was running smooth, I mounted the ballscrew, in the same manner. One end first in one plane, them attached a pice of rod to the coupler, and turn it with the tips of my fingers, and bit by bit, fixed all nuts until I could turn the ballscrew with the tips of my fingers for the whole 1420mm run.
With other word, beyond the language barrier: I have no clue what I did from a technical perspective. It just felt good enough. So could you please guide me towards a reliable way or alligning the y axis rails and ballscrew. :)
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
