01-08-2018 #27
Hi John,
ˇˇwhat could be a problem is having the BOB's output optoisolator being connected to another optoisolator inside the stepper driver/having the step signal passing through two optoisolators could distort the pulses too much at high step ratesˇˇ - does this mean I should remove the bridge from enbl+?
ˇˇwhat I need to confirm is the connection of the 10K resistor connected to the 74HC14 input/it was not clear from the photos if the resistor was a pull up to +5v or pull down to GNDˇˇ - how exactly can I help in confirming this?
P.S. although I have some general knowledge about diodes, capacitors and resistors, I.m struggling to wrap my head around schematics, so I.m sorry if my replies are quite banal. I very much welcome reading material to avoid pushing the limits of anyone.s patience. :)
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
