02-08-2018 #28
Has the enable been connected up yet ?
I would common all the +v inputs to the drivers and use -ve pulses to drive enable, step and direction. There again, I wouldn't use that BoB as it has no relay output (though these can be added with a cheap board) and no 0-10v speed control.
I happily use this board https://www.dropbox.com/s/gfq4isvihn...rd-EN.pdf?dl=0 and have only blown one of them so far (my own stupid fault). At least they are cheap
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
