Page 5 of 27 FirstFirst ... 3456715 ... LastLast
  1. #41
    . I very much welcome reading material to avoid pushing the limits of anyone.s patience. :)
    Don't worry about this. I believe John is very experienced in electronics. Just go through it with one small step at a time.
    Also have you disabled all the crap like screen savers and stuff in the bios that is not needed on the pc.
  2. #42
    combining the circuit of one of the BOB outputs with the circuit f the stepper driver inputs :-
Name:	optoisolated BOB output to optoisolated driver.jpg
    when the printer port or motion controller goes high
    the output of one of the inverters in the 74HC14 goes low and
    about 10.6mA flows through the opto isolators LED
    the light turns on the NPN photo transistor that in turn pulls the
    stepper driver negative input down to ground
    (- step in the circuit example)
    about 16mA flows through the stepper drivers input LED
    the problem is when the BOB input goes LOW
    the BOBs opto isolator LED is turned off but the NPN transistor takes a while to turn off
    the square edge of the step pulse gets rounded off
    delaying when the stepper driver LED is turned off
    while I expect a faster opto-isolator is used inside of the stepper driver
    the NPN photo transistor inside the drivers opto-isolator will further degrade the step pulse
    John
    PS
    propagation delay through a high speed opto-isolator
    not only is the signal delayed but the edges are rounded - see page 4
    PPS
    in another thread to use surplus Tormach stepper drivers
    https://www.cnczone.com/forums/torma...ml#post2107952
    from the above post
Name:	10 pin connections .jpg
    you can see the Tormach / Leadshine stepper driver uses a HCPL 2531 dual high speed opto isolator for the step & direction inputs
    a slower FL817 opto-isolator being used for the enable input
    the "817" being the opto-isolator I expect your BOB to have
  3. #43
    Clive: yep, no such thing on this 12+ years pc, has a built in parallel port, windows 7 32 bits, no aero theme or screensaver. I don.t know what are the bios things which I don.t need.
    John: ok, got the point a light and a sensor which acts like a switch and this one does not work fast enough. Now changing the drivers (wantai) is not possible, and buying others costs a bit.
    Changing or upgrading the optoisolator in drivers or bob is I guess problematic. Like chancing the tiny chip on a pcb, is doable, and I have some tools for that, but not the skills just yet.
    I can buy another Bob, if it helps. Should I, and if yes, which one?
  4. #44
    I would try another BOB that does not have opto-isolated outputs
    and either has 74HC14 HEX inverters connecting the printer port outputs to the stepper driver inputs or 74ACT245 octal transceivers as used on the C10 BOB
    the C10 has no opto-isolators on either the inputs or outputs
    note this BOB
    has a design flaw
    if you look at the 74HC14 used for the inputs
    the supply pi 14 is not connected !!!
    see top left hand corner of the circuit diagram
Name:	chinese breakout board.jpg
    John
  5. #45
    Has the enable been connected up yet ?
    I would common all the +v inputs to the drivers and use -ve pulses to drive enable, step and direction. There again, I wouldn't use that BoB as it has no relay output (though these can be added with a cheap board) and no 0-10v speed control.
    I happily use this board https://www.dropbox.com/s/gfq4isvihn...rd-EN.pdf?dl=0 and have only blown one of them so far (my own stupid fault). At least they are cheap
  6. #46
    I found both ones available in my area, 22 euro for db25 (with relay), and 30 euro for the C10 (if it works with that flaw)
    Also HDBB2 at apx 50 euro https://www.ebay.com/itm/HDBB2-break...sid=m570.l1313.
    So I.ll get any of these, now the tricky part is which one?
    Also have available UC300ETH, but it is expensive as hell, apx 150 euro
  7. #47
    Quote Originally Posted by Radu_Andrei View Post
    Like this;- https://www.ebay.co.uk/itm/5-CNC-Axi...4AAOSwaxlZiq98
    These boards require 5v and 12-24v for the inputs and speed control to work
    You can buy them from China as well:- https://www.aliexpress.com/item/5-Ax...ceBeautifyAB=0
  8. #48
    Probably shipped from China (their Engrish warehouse).
  9. #49
    this BOB
    is the type of BOB I would use
Name:	ebay CNC BOB (2).jpg
    it looks like its a version of this BOB found in some control boxes supplied with some 6040 CNC machines
Name:	TX14175 circuit.jpg
    the TX14175 has the advantage of having a 5V to 5V DC converter to provide the isolated 5V supply for the 75HC245's
    instead of taking a 5V supply from a USB port
    the HDBB2 looks good
    I am not sure why they have used a expensive 36 way centronics connector instead of a 25 way D-type connector
    John
  10. The Following User Says Thank You to john swift For This Useful Post:
  11. #50
    Ok. Thank you. Will order today. :)
  1. Need a bit of help with servo settings/setup
    By alboy in forum General Discussion
    Last Post: 07-06-2018, 11:04 AM
  2. PWM Settings
    By Gunar in forum General Electronics
    Last Post: 16-02-2017, 12:33 PM
  3. Mach 3 default settings,
    By chris w in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2016, 01:54 PM
  4. Home Switches & Slave Axis in Mach 3
    By Tenson in forum Artsoft Mach (3 & 4)
    Last Post: 03-03-2014, 11:43 PM
  5. Help with settings!
