11-08-2018 #11
great to see you have it working even if your not 100% sure which connection you re-made during your investigation
your connection to the VFD looks correct
in practice using the 12V supply probably will work
while the LM317's data sheet gives the minimum supply voltage as V out +3V this will be the worse case accounting for the production spread in the IC's parameters
even if the supply is too low for the regulator to regulate the output as intended
the fact you have a regulated 12V supply
the voltage is likely to be near to 10V and not change too much and
cause the calibration of analogue control voltage to the VFD to vary
John
The Following User Says Thank You to john swift For This Useful Post:
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
