Taking on your advice, and speaking to an electrician, a retired one in this case, he said they use to drive 3 spikes into the ground, a few meters apart, and weld a connection between them, so that the earth might match the live, and have a specific ohm readings, so that the fuse will work properly. He used to practice he.s craft many years ago, so not sure if his knowledge it.s still valid with this new fuses.
Also said that the large metal structure from the photo has a very solid grounding structure going on, so I might use this. That is a high voltage system, and I.m not sure if it goes well with 220v systems.
That.s the best I could find today, as we have a holiday going on, but will check with the up to date electrician as well.
Will fix this earthing problem asap.
Meanwhile, I,ll do some research about this gearing inputs I need to make.
Thank you.
15-08-2018 #2
Meanwhile just knock a copper tube in and connect to you mains earth. It has to be better that getting small electric shocks
15-08-2018 #3
In settings tab, I typed I want to move it 50, and it did move 150, and mach 3 set it to 160 steps. Now in mdi tab, I typed g1 x100 f300, it moved 100mm but very very slow.
The driver setting is at 800.
I did try g1 x100 f2000 but still slow, so I honestly have no clue what this means, if it.s just the the speed used in this setup, or the speed of the machine, or anything else. As I said, I need to study some basic things about this, so I would guess it.s easier if you.d guide me towards some reading material rather than test your patience, which was already strained since I started this topic.
15-08-2018 #4
P.s. John mentioned the spike. Rob clarified the water filling method.
My mistake. Sorry.
15-08-2018 #5Ok so now you have it moving the correct amount on the X axis.. Now change the driver steps to 1600 and do the same test re calibration. Also tell us what you have set the settings for on the motor tuning page Mach3In settings tab, I typed I want to move it 50, and it did move 150, and mach 3 set it to 160 steps. Now in mdi tab, I typed g1 x100 f300, it moved 100mm but very very slow.
Just test with one axis first
re the spike, it is the same as earth rod . Re the water it was just to wet the ground around the rod to lower the resistance of the earth.
Don't worry about the questions, we have all been there at some point.
edit https://www.youtube.com/watch?v=R3fu...M7iZbmHUxO7K-uLast edited by Clive S; 15-08-2018 at 02:57 PM.
15-08-2018 #6
ok. i cut the power to the drivers, and changed to 1600 (on, off, on, on), and tried again, and now it moved half the distance, example move 50, and it did 25, and mach 3 set it to 320. typing in mdi the same thing, it moves the right distance typed in but somewhat faster.
in motor turning, the "steps per" is set by this test, velocity 600 mm per minute, acceleration 50, G's 0.0050988, step pulse, dir pulse both to 0
15-08-2018 #7
Ok you are now moving the correct amount. You now have to alter the vel. 600mm is slow try 1200mm then 2400mm . You have to ajust the vel. and accc. for your specific machine.
The vel. is the max the machine can do. Ie if you set the feed rate with your settings (600mm) it will be clamped to that. So if you say f2000 it can't go any faster than 600
Did you watch the vid?..Clive
15-08-2018 #8
I did watch the video. I.ve seen it a month ago when I first installed mach 3, but did it again to see what I.ve missed.
I attributed the frame shake related to a gantry hard stop, with a sign that I.ve reached the speed limit on the machine, on the Y axis for example.
If it could accelerate and decelerates slower while running a g code, it could travel quite faster, but I don.t know if it.s possible. And honestly it.s not a requierment for me, as I.m not into large quantity production, but rather in custom or special products approach. For example, the first projects that I need are plexiglas stencils used to decorate some furniture with a traditional motif.
There is a guy called Roger Webb on youtube which does some decorative wood projects, and the cutting time for a 50 by 50 cm sculpture ranges between 2 to 4 hours in 2 cuts. I.m aiming for that, and I don.t think that is a high expectation but do correct me of I.m wrong.
I.ll test some speeds, but what am I looking for? How else can I know the max the machine can do?
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
