01-09-2018 #24
In the video, it looks and sounds like the stepper is stalling,In the Motor Tuning, try dropping the velocity and acceleration to 50% of what you have got it set at. If this solves the problem put it up to 75% of the original value. Then go up until it stalls and back off to where it doesn't stall.
If that doesn't help you then we have to think deeper.
Sw4 puts it to half current when idle and is normally set on.Last edited by cropwell; 01-09-2018 at 02:52 AM.
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
