01-09-2018 #23That is 6 mtr/ min. I doubt your machine with go that fast. Are you using belts between the motor and screw or direct drive?The z axis for example was set at 100 mm/sec,
Turn SW 4 on. It will not affect anything when the motor are moving. when the motors stop it just reduces the current to half.
Only play with 800 Sw 5-6-7-8 = off-on-on-on - it is not rev/min.- it is pulse/revAs for steps, I.ve tried 800.1600 and 2000 rev/min. It either function ok with any setting or it does not work, no matter the steps.
What exactly do you have your motor tuning in Mach3 for each axis.Last edited by Clive S; 01-09-2018 at 10:48 AM.
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
