02-12-2018 #22
Hi Paulus.v
I also have an emergency estop which cuts power to everything, except the pc and the BoB, but I have never used it. (this being the hardware stop). I did, however used the software estop (input terminals on BoB) a few times, when I messed up gcode programing, and it worked quite well.
Your representation of the work conditions in which the cnc will function are a bit dramatic for a work shop, as I.m quite sure it is not positioned under a waterfall, but as I cannot help notice the flag situated at the left side of your user name it.s quite similar with mine, I think such a Estop described by you, should be very helpful if assigned to our prime minister, leading party and most of the political machine that is running our country. :) Best whishes, and happy national day for 01.12.2018! :)
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
PWM Settings
By Gunar in forum General ElectronicsReplies: 20Last Post: 16-02-2017, 12:33 PM -
Mach 3 default settings,
By chris w in forum Artsoft Mach (3 & 4)Replies: 4Last Post: 08-01-2016, 01:54 PM -
Home Switches & Slave Axis in Mach 3
By Tenson in forum Artsoft Mach (3 & 4)Replies: 14Last Post: 03-03-2014, 11:43 PM -
Help with settings!
By Tenson in forum General DiscussionReplies: 26Last Post: 30-09-2012, 11:26 PM
