    Quote Originally Posted by Radu_Andrei View Post
    Regarding your post, ˇˇThe difficult part is bolting down the first rail absolutely straight.ˇˇ, before doing that, is it not necessary to set the y axis linear bearings/rails absolutely perpendicular to the x axis rails?
    Actually, getting the gantry square to the other rails is one of the easiest adjustments, and it was almost the last thing I did. I am assuming that you are able to adjust the gantry - in my case, I can loosen the bolts between the gantry and the plates which carry the bearings so that if I turn one ballscrew, I adjust the "squareness" of the gantry. So, get it as close to square as you can - I used a carpenter's square - and then cut a test piece. As someone has suggested, drill four holes on the corners of a square and measure the diagonals. I used the shanks of drills as pegs in a piece of MDF, having used the same size drill to make the holes. With a little bit of schoolboy trigonometry, you can then work out how much you need to turn just one of the ballscrews driving the gantry to bring it into square. Tighten bolts and check again. I wrote a short piece of gcode to drill the holes so that I could ensure that I always approached the holes from the same direction to remove backlash from the process.
    My very final adjustment was to use the machine itself to skim the strips of wood I use as bed supports so the the bed was reasonably flat once I screwed down a sheet of plywood. Not good enough for precision metalwork, but this is a woodworking machine. I machine a smaller spoil board if I want more depth accuracy for a particular job.
    Good luck!
  1. Need a bit of help with servo settings/setup
    By alboy in forum General Discussion
    Last Post: 07-06-2018, 11:04 AM
  2. PWM Settings
    By Gunar in forum General Electronics
    Last Post: 16-02-2017, 12:33 PM
  3. Mach 3 default settings,
    By chris w in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2016, 01:54 PM
  4. Home Switches & Slave Axis in Mach 3
    By Tenson in forum Artsoft Mach (3 & 4)
    Last Post: 03-03-2014, 11:43 PM
  5. Help with settings!
