    RouterCNC - thanks for taking the time to explain all that, I appreciate it. I've had a bit of a play with your stiffness calculator spreadsheet and I'm getting gantry deflection of <0.05mm as I would expect following Jazz's advice.
    I think I'm going to redo my frame design using 60x60x5 for the legs, 120x60x5 for the rail supports and maybe use 50x50x4 for the bed and triangulation / stiffeners.
    Quote Originally Posted by JonnyFive View Post
    I wouldn't take that route as the difference in steel price won't be massive. It will make welding more difficult because of your mixing different thicknesses and tube sizes.
    At this width, the bed will be much less resonant with the thicker, wider tube size giving a better finish on parts. Esp when cutting harder materials that will resonate into the bed and frame.
    Keep in mind it's the foundation of the whole machine. It really isn't worth spoiling the broth for apeth of salt.
    Where's yer grammar lad? "It in't worth spoilin' t' broth for an ha'p'orth o' salt"
    Tha's reight old lad, cummin from't God's own country a shuda known bet'ta, but think tha'll fi'nd it's spelt ha'peth.!!. . . . cos we'll av non that posh "orth" rarynd here si'thi.
    My dad was pure-bred Yorkshire (though he was born in Karachi, only because his mother was there at the time) but was educated at Cambridge so the odd posh turn of phrase was known to escape his lips. Not often, mind!
    Kit
    Understood, you're right, if it's worth doing it's worth doing right. I'll crack on with 60x60x5 & 60x120x5.
    Cheers!
  1. BUILD LOG: Router Build Mk 1
    By hoppo in forum DIY Router Build Logs
    Last Post: 14-08-2017, 08:31 AM
  2. Router build
    Last Post: 18-12-2014, 07:19 PM
  3. RFQ: Does anyone want to build me a cnc router?
    By totally useless in forum Projects, Jobs & Requests
    Last Post: 08-05-2014, 09:55 PM
  4. BUILD LOG: My Router Build!
    By andy0202 in forum DIY Router Build Logs
    Last Post: 31-01-2013, 08:51 AM
  5. BUILD LOG: A3 Router Build
